C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Stage II LS7 cylinder heads - A visual guide to valve guide wear and CNC upgrades
Old 06-25-2013, 11:36 AM
0Daniel@Vengeance
Former Vendor
Daniel@Vengeance's Avatar
Default Stage II LS7 cylinder heads - A visual guide to valve guide wear and CNC upgrades
We see a lot of LS7 cylinder heads here at Vengeance Racing and in our experience the valve guide issue is quite real and very problematic. Now, we're not here to sell anyone a set of heads (although we would be happy to ) but mainly to offer a place to ask questions and get answers.
If you are not famiiar with the LS7 valve guide issue, it is essentially a factory machining/installation error that causes excessive valve guide wear, which eventually allows a valve to drop or hang, which can be catastrophic. You can see what happens when a valve drops below...
GM attempted to ignore the situation at first, but after enough complaints they finally issued the following statement:
Hello all,
LS7 Valve guide issue summary:
• Affects a small, number of '08, 09 ’10 and ’11 Z06’s
• GM discovered the condition through our cylinder head warranty data involving a very small percentage of our vehicles.
• Through inspection of returned heads, it was determined that a machining error in the valve guide had occurred at our head supplier.
• The quality issue has been contained as of Feb 2011 with 100% inspection of all heads.
• The most common customer complaint has been excessive valve train noise.
However if the condition is not addressed, it could result in engine failure. To date, where this condition has been observed, it has occurred early in the vehicle life.
What customers need to know: They should drive and enjoy their vehicles without fear. If their car demonstrates this condition, they are likely to hear unusual valvetrain noise first....
Many enthusiasts have been looking a proactive approach to fixing the issue, which always results in removing the cylinder heads. Here at Vengeance, we see this as a perfect time to upgrade the already awesome LS7 units and the majority of our customers agree. But first, let's look at a quick and dirty way to determine irregular valve guide wear. This is NOT the best way to preform this work and we have every guide checked by our cylinder head machinist using a specific valve guide bore gauge, but most people don't have one of those. So, for the do-it-yourself mechanic, this is an easy way to check heads on the bench.
With a dial gauge attached directly to the cylinder head, it easy to get a quick and dirty feel regarding valve guide wear. This is our starting (zero) point...
...and here we have the valve pushed all the way up. 0.019-inches of play.
Here is a head with new bronze valve guides installed:
0.006-inches of play. Much better!
Again, that's quick and dirty. We recommend having a professional check every guide with a valve guide bore gauge (which we do) before and after the installation of new bronze valve guides. Or don't check them and just change them out, you won't regret it!
Besides correcting the valve guide issues, let's check out the rest of the VR/WCCH Stage II LS7 Cylinder Heads.
The stock combustion chamber prior to hot tanking and blast cleaning:
After hot tanking and blast cleaning:
With the valve removed, we can compare the stock valve job:
To the new VR/WCCH competition valve job:
And here are the two heads side by side, to show the before and after:
In addition to installing new valve guides, every stage II LS7 head features CNC-ported intake and exhaust runners for maximum power output.
The exhaust port features CNC-porting as well:
Each VR/WCCH Stage II LS7 cylinder head comes with a new set of one-piece stainless steel exhaust valves and tumble polished Titanium intake valves. The stainless steel valves are brand new, while the Ti valves are inspected, cleaned, and polished OE units.
Here you can see the stock valves out of a factory cylinder head:
And here are the a new set of valves. Stock diameter, although the exhaust valve has been upgraded to a one-piece stainless steel unit, and the intake valve has been polished to reduce valve guide wear.
The heads are gorgeous and safe but besides that, they flat out make power!
Exhaust port flow at at .600 is up 18.5cfm thanks to the CNC port work, from 226.3cfm to 244.8cfm. At .700-inches, the ported LS7 flows 250.6 compared to just 228.8 from the stocker.
The intake runner CNC work shows even bigger gains (using the stock valve!) with .650-inch flow up to 395.4cfm from a chocked 333.1 - That's a gain of 62.3 cfm
Of course, the real question is, what will this do on an LS7 engine? In our experience a Stage II cylinder head swap is worth 30-40rwhp in back-to-back testing.
On a well appointed C6Z with a VR camshaft plus kit, a set of quality long-tube headers, and the correct bolt-on parts, these heads are good for ~600rwhp and 520 ft-lbs of torque.
At any time, Vengeance Racing has 4 sets of Stage II LS7 cylinder heads in rotation, heading out (excuse the pun) to customers all over the world. Of course, we will be happy to answer any questions regarding this process and we welcome any discussion involved with LS7 cylinder heads in general.
Old 06-25-2013, 11:59 AM
Dre01SS
Dre01SS's Avatar
Great, informative post guys... That dyno graph looks familiar
She was stout at the track, ran great all weekend long - but in this GA weather and frequency, I think I see a Ron Davis in the near future. Will keep you posted!
Old 06-25-2013, 12:12 PM
wolf8218
wolf8218's Avatar
Any consideration for those who don't want stainless steel valves?
Old 06-25-2013, 12:57 PM
Random84
Random84's Avatar
Nice write-up.
Old 06-25-2013, 01:21 PM
FSTFRC
FSTFRC's Avatar
Informative write up ... thanks for sharing....
Old 06-25-2013, 02:24 PM
8850's Avatar
Nice work guys! Would like to have a set but I have a 2012 so hopefully GM fixed the valve guide issue in 2011 and mine will be trouble free.
Old 06-25-2013, 02:31 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Very nice write up.
Old 06-25-2013, 03:08 PM
DaOtherOne
DaOtherOne's Avatar
Old 06-25-2013, 03:45 PM
blackbeast99
blackbeast99's Avatar
Old 06-25-2013, 04:40 PM
0Ron@Vengeance Racing
Former Vendor
Ron@Vengeance Racing's Avatar
Dre,
Glad to hear your track outing went well!!! Ga heat is brutal Let me know when you are ready for that Ron Davis/Spal fan combo.
Old 06-25-2013, 06:01 PM
04_Z06_CE
04_Z06_CE's Avatar
By far the most informative thread with pics. Thanks guys.
Old 06-25-2013, 06:30 PM
Dirty Howie
Dirty Howie's Avatar
Well this is a very nice presentation
And an open offer to discuss/answer the valve train/head issues is outsatnding.
So here is my question: Should I rip my WCCH off and yank the SS exhaust valves out of them based on your competitors recent spintron tests ????
DH
Old 06-25-2013, 06:36 PM
jimman
jimman's Avatar
Curious I hear the term, “a lot” spoken on the forum, can someone define that. To me “a lot” would be like 10 a week????
Old 06-25-2013, 08:08 PM
erikszr1
erikszr1's Avatar
atleast
Old 06-25-2013, 10:24 PM
spinkick
spinkick's Avatar
If its a machining/installation problem, why do the exhaust valves need to be changed? Could we not continue to use the sodium filled ones or go to Ti as well?
Old 06-25-2013, 10:39 PM
Gary '09 C6
Support Corvetteforum!
Gary '09 C6's Avatar
thank you VR.
Old 06-25-2013, 11:27 PM
04_Z06_CE
04_Z06_CE's Avatar
Lol. No.
To Stage II LS7 cylinder heads - A visual guide to valve guide wear and CNC upgrades
Old 06-26-2013, 12:47 AM
nzk
nzk's Avatar
I too would like to know why not just do bronze guides, polished intakes, and new OEM exhaust valves? The valves arent defective, just the guides correct? the bad guides damage the valves, valves break. that's the prevailing theory.
Old 06-26-2013, 05:19 AM
z0sicktanner
z0sicktanner's Avatar
Originally Posted by Ron@Vengeance Racing
Dre,
Ron would you agree that the stock exhaust valve isn't dealing with the heat the way it should? great post by the way well done Wcch gets it done those flow numbers are crazy
Old 06-26-2013, 06:17 AM
MarkC
MarkC's Avatar
C2 of Year Finalist (performance mods) 2019
I had my car done by Vengeance in February with the Stage 2 heads and tune. I also did the Halltech 103 cai. I dropped the car off Monday morning and picked it up Tuesday afternoon. The price was the same as the quote with no surprises. They have a very professional staff and they even washed my car for the ride back to Virginia Beach. 100 percent satisfied. Why go to stainless values, because they are stronger than the sodium filled, cheap and they work. BTW, my buddy Andy dropped his car off at the same time and the did both cars together. I doubt some dealerships could do that.
Quick Reply: [Z06] Stage II LS7 cylinder heads - A visual guide to valve guide wear and CNC upgrades
