C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] WCCH-X/Widow before and after headers/E85 dyno
Old 09-07-2013, 01:35 PM
SlowVet05
SlowVet05's Avatar
Default WCCH-X/Widow before and after headers/E85 dyno
Some of you may remember a thread I started a while back about my H/C results:
http://forums.corvetteforum.com/c6-z...x-results.html
Well I finally got some headers on there and had it tuned on E85. Setup now is:
WCCH-X heads milled .030
Widow cam
Halltech MF103
Stainless Works 1 7/8 headers with gutted cats
85lb. injectors
E85
Peak gains after the headers/E85 were 45rwhp and 48rwtq but the gains under the curve were pretty crazy. Down low I picked up almost 100rwtq! The car was dyno'd in 109 degree Phoenix weather so when it cools off outside I'm sure the numbers will come up a little. The dyno numbers don't concern me because the car pulls like a monster now. Now I know what all the fuss is about H/C C6Z's. Moral of the story: Don't do a big *** heads/cam package without headers
Big thanks to Joe and the crew at CPR. Joe has been helpful throughout the entire build and responds almost instantly to whatever questions I've had, and I've had a LOT. If you need LS work done in AZ, I recommend you check them out.
Old 09-07-2013, 08:16 PM
JMB
JMB's Avatar
Very nice!!! What was total timing this time?
Old 09-07-2013, 09:41 PM
CHIWS6
CHIWS6's Avatar
great numbers! what changes did u do to the fuel system in order to run e85?
Old 09-07-2013, 09:59 PM
SlowVet05
SlowVet05's Avatar
Not sure on the timing. Bigger injectors is all I needed to run E85.
Old 09-08-2013, 06:53 AM
Sik Six
Sik Six's Avatar
I just got my WCCH-X heads put on and I have the widow cam/headers/Halltech intake/Bullet exhaust and my car made almost the same numbers as yours. Mine made 550/490. Only have 91 octane here in Oklahoma.
Old 09-08-2013, 11:01 AM
VictoryRedZ06
VictoryRedZ06's Avatar
Congrats and nice numbers, what are the specs of the widow cam? Also how much does it cost to do a E85 conversion? Thanks
Old 09-08-2013, 11:09 AM
SlowVet05
SlowVet05's Avatar
Carlos doesn't release the specs, but it's BIG. E85 conversion for me was just the cost of injectors which I found used for $225.
Old 09-08-2013, 11:13 AM
VictoryRedZ06
Wow cool! If I just convert to E85 how much rwhp and rwtq would I gain? I have heads/cam also NO headers since Im in California
Old 09-08-2013, 11:29 AM
SlowVet05
SlowVet05's Avatar
I didn't get a 91 tune but from what I've seen from a few buddies of mine you can expect about 20/20 gains.
Old 09-08-2013, 11:32 AM
VictoryRedZ06
Thanks its definitely worth the conversion
Old 09-08-2013, 03:34 PM
C6 Curtis
C6 Curtis's Avatar
Why the numbers so low on a dynojet. shouldn't it be 600 area on E85?
Also congrats on the new set up.
-Curtis
Old 09-08-2013, 04:29 PM
SlowVet05
SlowVet05's Avatar
-Curtis
I'm not too concerned about the dyno numbers, the car pulls like a beast so I'm happy with it.
Old 09-08-2013, 04:35 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
-Curtis
Ambient was 109* Would like to see it again at 65-70*...
That's what matters
Old 09-08-2013, 09:45 PM
My 07 Z
My 07 Z's Avatar
You don't have to upgrade the pump when you go to E85?
Old 09-08-2013, 10:03 PM
SlowVet05
SlowVet05's Avatar
I didn't have to.
Old 09-08-2013, 10:35 PM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,228 Likes on 775 Posts
-Curtis
no z in az will get there w/o being high compression
at his power level no but around 575 rwhp they start to run out of pump. the walbro 450 is a great replacement.
Old 09-08-2013, 10:41 PM
smellya
smellya's Avatar
I have a 06 z06 with a synergy smog set up heads and cam. Through manifolds it made 548/503. It does have a katech bottom end in it.
To WCCH-X/Widow before and after headers/E85 dyno
Quick Reply: [Z06] WCCH-X/Widow before and after headers/E85 dyno
