C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Computer settings
Old Oct 11, 2013 | 10:50 AM
Rupert pupkin's Avatar
Rupert pupkin
Default Computer settings
Kind of a nooooob question, but how do you completely turn off the active handling on an 07 Z. I know if you press the button in the middle console, it will turn off TC and/or turn on sport mode. I want all computers off.
Old Oct 11, 2013 | 10:58 AM
KING_PIN6's Avatar
KING_PIN6
you should hold the button for few second then it will turn off ..AND YOU WILL BE ON YOUR OWN
Old Oct 11, 2013 | 10:59 AM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
To turn the system off, press the ACTIVE HANDLING button on the console for five seconds. You can turn the system on at any time by pressing the button. The DIC will display the appropriate message when you push the button.
Old Oct 11, 2013 | 11:02 AM
VetteVinnie's Avatar
VetteVinnie
And if you're a noob, why on Earth would you want to disable the system? Are you anxious to redecorate a guardrail or something?
Old Oct 11, 2013 | 11:33 AM
Rupert pupkin
I tried holding down the button for 5+ seconds and nothing. Held it longer and nothing. Noob question..but not a noob driver...thanks. Cant stand active handling.
Old Oct 11, 2013 | 11:38 AM
GMuffley's Avatar
GMuffley
It's all in the owners manual.
Old Oct 11, 2013 | 12:01 PM
Rupert pupkin
I knew you had to hold down the button, thats why ive been tryng to do it ever since I got the car. Idk if there was a different way since it wasnt working.
Old Oct 11, 2013 | 01:30 PM
Fifedogg's Avatar
Fifedogg
I hate the traction control but like the active hadling myself. Hold the button down when your in regular mode it will work...
Old Oct 11, 2013 | 01:47 PM
chrisfromalbany's Avatar
chrisfromalbany
I had all the systems on, was taking heavy downhill turn fast, hit a bump, back end came out, got alittle sideways and glad that system was there. I was scared my steering correction and slight tap of the brakes would lead to over-correction the *** coming out the other direction. That didn't happen, otherwise I be in the guard rail.
I wasn't sure if it was going save me and correct the turn but it did. Needless to say, it was alittle scary.
Old Oct 11, 2013 | 02:29 PM
Rupert pupkin
Im assuming you were in a course? +1 for keeping the system on.
To Computer settings
