[Z06] Sparco,Sabelt,Schroth Seat & Belt Packages
Former Vendor
St. Jude Donor '13
Sparco EVO II US Competition Seat w/ Steel Side Mounts (Black)/Planted Seat Bracket w/Schroth Profi II-6 Seat Belt 6 point (Black) Competition Package Driver Side
Competition Package Includes
(1) EVO II US Competition Seat Black
(1) Sparco Competition Side seat Mounts Black
(1) Set Schroth Profi II-6 Seat Belt 6 point Black
(1) Planted Floor Mount Seat Bracket Black Driver Side
http://www.xplosiveperformance.com/S...de_p_3413.html
$1,389.95
Shipped free lower US
Sparco EVO II US Competition Seat w/ Side Mounts (Black)/Planted Seat Bracket w/Schroth Profi II-6 Seat Belt 6 point (Black)/HardBar Harness Bar Competition Package Driver Side
(1) Planted Competition Side seat Mounts Black
(1) Hardbar Competition Harness Bar
http://www.xplosiveperformance.com/Sparco-EVO-II-US-Competition-Seat-w-Side-Mounts-BlackPlanted-Seat-Bracket-wSchroth-Profi-II-6-Seat-Belt-6-point-BlackHardBar-Harness-Bar-Competition-Package-Driver-Side-_p_3507.html
$1717.97
For the Wider and Bigger Guys
Sparco EVO III Competition Seat w/ Side Mounts (Black)/Planted Seat Bracket w/Schroth Profi II-6 Seat Belt 6 point (Black)/HardBar Harness Bar Competition Package Driver Side
(1) EVO III Competition Seat Black
http://www.xplosiveperformance.com/Sparco-EVO-III-Competition-Seat-w-Side-Mounts-BlackPlanted-Seat-Bracket-wSchroth-Profi-II-6-Seat-Belt-6-point-BlackHardBar-Harness-Bar-Competition-Package-Driver-Side-_p_3550.html
$1747.95
For the Wider & Taller Drivers
This Package is for the Larger Drivers. The seat is wider and the seat rails give you the maximun head room height available
Sparco EVO III Competition Seat Black w/Aluninum Flat seat rails for C4/C5/C6/C6 ZO6- Plain
http://www.xplosiveperformance.com/Sparco-EVO-III-Competition-Seat-Black-wAluninum-Flat-seat-rails-for-C4C5C6C6-ZO6-Plain_p_3556.html
$1175.95
SABELT
Racing Harnesses, Seats, and Safety Products now at XP Motorsports
Passion for speed is overwhelming. When your foot pushes on the accelerator, the adrenaline of holding a steering wheel reaches a maximum level, together with the sound of the engine, there is only one goal in mind: to be the first! To reach victory following one's own instinct, a driver must have the absolute certainty that everything that surrounds him inside the car has been carefully studied and calculated to the finest detail.
At Sabelt USA & XP Motorsports we sell the parts & equipment you need to win and win safely. With our collection of top quality auto racing suits, racing gloves, racing shoes, racing belts and harnesses, racing seats and steering wheels, Nomex accessories and more, we'll get you to the Winner's Circle in one piece and looking great.
With your passion for Auto Racing and our passion for Safety, Quality and Fashion - we're an unbeatable team!
Sabelt Racing Taurus Fiberglass Large Seat - Black
http://www.xplosiveperformance.com/S...ck_p_3589.html
Sabelt Racing Taurus Fiberglass XLarge Seat - Black
Ideal for larger drivers (over 240 lbs or up to 38- to 42-inch waist)
http://www.xplosiveperformance.com/S...k-_p_3590.html
$750.00
delivered lower US
$1,389.95
$1717.97
$1747.95
$1175.95
SABELT
$750.00
delivered lower US
Sabelt Racing Seat Titan Large - Black
http://www.xplosiveperformance.com/S...ck_p_3587.html
Sabelt Racing Seat Titan XLarge - Black
http://www.xplosiveperformance.com/S...k-_p_3588.html
$645.00
delivered lower US
Harnesses
In F1 Sabelt Harnesses Have Been Chosen By Ferrari, Williams, Red Bull and Toro Rossa
Sabelt HANS Steel Adj., 6Pt.,
3+2" Shoulder, 3" Lap, Saloon Style, BLACK or RED, PULL DOWN, Eyebolt
http://www.xplosiveperformance.com/S...t-_p_3582.html
Sabelt Steel Adj., 6Pt., 3" Shoulder, 3" Lap, Saloon Style, BLACK or RED Pull Down Eye Bolt Mount
http://www.xplosiveperformance.com/S...nt_p_3578.html
$312.00
Delivered lower US
See all the SABELT Harnesses and Seats
http://www.xplosiveperformance.com/S...g_227-1-1.html
We have all the mounting Hardware you will need to install harnesses,seats, safety products into your car
http://www.xplosiveperformance.com/S...me_p_3593.html
Hardbar seat rails for C4/C5/C6/C6 ZO6- Plain
http://www.xplosiveperformance.com/Hardbar-seat-rails-for-C4C5C6C6-ZO6-Plain_p_3545.html
$365.00
Sparco quick release Black
$645.00
delivered lower US
Harnesses
$312.00
Delivered lower US
$365.00
http://www.xplosiveperformance.com/Sparco-quick-release-Black_p_3555.html
$305.00
Pfadt Steering Wheel Adapter
http://www.xplosiveperformance.com/Pfadt-Steering-Wheel-Adapter_p_3554.html
$150.00
Sparco steering wheel
http://www.xplosiveperformance.com/Sparco-steering-wheel_p_3553.html
$258.95
Delrin shift ****, extra long
Delrin shift ***** are CNC machined from solid genuine DuPont Delrin. Unlike aluminum or titanium *****, the Delrin is great in that it does not burn your hand in the Summer heat, nor does it seem cold in the Winter. They are made for each application and do not use inadequate set screws that can and do loosen like the one-size-fits-all generic *****. The C4/C5 ***** are fully threaded internally, whereas the C6 ***** are made specifically for the C6/C6ZO6 and use the stock Torx head screw in the machined counterbore. They are easily installed and easily removable. C6 extra long shown.
http://www.xplosiveperformance.com/-...ng_p_3551.html
$65.00
C4/C5/C5ZO6/C6/C6ZO6 Hardbar Coupe Harness Bar
Allows Perfect Placement Of Performance Belts
* Allows Belts To Hold You Securely In The Seat So You Concentrate 100% On Driving
* Bar Is Stiffer, Stronger & Lighter Than Any Other Bar
* Supplied In Black Powder Coating Wrinkle Finish
* Shown In Bright Metal For Photo Purpose Only Hardbar's Harness Bar uses your stock belts or any other racing belt with a wrap around loop. The bar is easy to install and remove. It's made of aerospace aluminum and weighs less than 6 pounds. In addition, the bar stiffens the chassis. Standard seat belts are routed over the backrest and sport seat can do either over or through the backrest. It does require minor modification to the plastic interior panels, template included.
Pre-cut panels available.
http://www.xplosiveperformance.com/C...es_p_3414.html
$360.00
ESS 5.0 Liter AFFF Fire Suppression System
Aqueous film forming foams (AFFF)
The 5.0 liter system is a racing approved system by SCCA, PRO-SCCA, Trans Am, World Speed Challenge, American LeMans, NASA, and others. This is a 4 nozzle, 3 zone system utilizing the newest T-style nozzle, bulkhead fitting, 20 ft of aluminum tubing and the other features of the 2.3 liter system. This system is available as an owner rechargeable system and as a SFI 17.1 compliant system. The SFI 17.1 compliant system requires that the systems be shipped full, sealed, and certified for 2 years of service. We offer a re-certification program for both 17.1 and non-17.1 systems. .
This system was created for the hardcore racer. It is designed to provide three zones of coverage - driver, engine, and fuel cell. The aluminum cylinder and hardware keep down the weight and yet the 5 liters of suppression agent provides better coverage than the competition. The 5 liter system will produce approximately 30 liters of foam when activated, enough to subdue the most stubborn fire. In non SFI 17.1 compliant systems, you clean up with water and can recharge the system at the track with a recharge kit (retail under $70) and fresh water. The SFI 17.1 compliant version of the 5.0 liter system requires that the system be shipped back to us for recertification. We offer a re-certification program for both 17.1 and non-17.1 systems. The stainless steel t-bolt mounting brackets allow easy access for tech inspection and storage during the off season.
http://www.xplosiveperformance.com/E...m-_p_2916.html
$510.00
Motul RBF600
http://www.xplosiveperformance.com/M...00-_p_648.html
Motul RBF600 is the best high-temperature Brake Fluid and preferred by many tuners and race teams. Its specifications and labratory results exceed that of DOT 5 silcone based fluid, but still retains the benefits of Glycol based fluid by lubricating the ABS pump and not deteriorating caliper and Master cylinder seals
100% Synthetic Brake and Clutch fluid. Compatible with all Dot 3 and 4 fluids. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems.
500ml bottles
$17.95
Motul RBF600 Case of 12
http://www.xplosiveperformance.com/M...12_p_3237.html
$215.40
Free Shipping Lower US
$305.00
$150.00
$258.95
$65.00
$360.00
$510.00
Motul RBF600
500ml bottles
$17.95
$215.40
05-13 Corvette C6/ZO6/GS/ZR1 Front Grille Mounted Brake Cooling Duct
http://www.xplosiveperformance.com/0...ct_p_3389.html
XP Motorsports 05-13 Corvette C6/ZO6/ZR1 Front Grille Mounted Brake Cooling Duct System
Everything you need to install grille mounted brake cooling in your C6 Corvette. The ducts fit behind the front grille no need to loose your fog lights. The ducts mount on the inner grille support (triming of the support is required). For ease of installation removal of the front bumper is required.
Kit Includes
(2) Large Brake Duct Vents
(2) Spindle Mount Brake Hose Adapters
(2) 3" Hose Clamps
(10Ft) High Temperature 550 degree Silicon Brake Hose
(1) Horn relocation Bracket
Mounting Screws
Instructions
$273.97
EARN YOUR REWARD POINTS FOR FUTURE PURCHASES EARN $1.00 for every $10.00 Spenthttp://www.xplosiveperformance.com/0...ct_p_3389.html
Kit Includes
(2) 3" Hose Clamps
Mounting Screws
Instructions
$273.97
ORDER ON LINE AND SCHEDULE YOUR INSTALL
Join us on Facebook
You should limit this more attention and buy really high quality belts and seat for your racing car. I did not do this and I had very bad. I had incident and had problems with my feet. But it's not so bad, because I started wearing Compression Stockings They help my feet. I feel much better. I advise you to devote more time to this issue.
