[Z06] need help cylinder head install
It appears I installed them backwards and the steam plugs are now well plugged, can I just drill them out or something cause I don't wanna pull my heads back off?
It sounds like the rear plugs are now installed in the front plug location. Quick and easy fix if so. Pull just the intake (with rails and throttle body still attached) and then move the plugs to the rear. Install front cross over tube. Reinstall intake and such. now its done! No need to remove the heads again.
Well I ended up drilling out the fronts, and hooked the stock ones up and I ordered the delete kit for the rears from Texas speed, seemed way cheaper and easier than pulling the heads lol
