[Z06] 2007 c6z06 Procharged
Ysi/F1R/F1X with at least an 8 rib, 10 rib would be better. Fuel system to support it. Forged bottom end, iron or upgraded block would be nice but not 100% needed. Clutch/drivetrain to support it. Swap to e85 or run methanol injector, unless you have access to 100+ octane pump gas. Cam and valve train too. Aftermarket heads would be a big plus, but could probably get there on factory heads.
