[Z06] rocker arm upgrade
rocker arm upgrade
any1 here anything about the ultra gold aluminum rocker arms, from comp cams, how much better are they then then ls7 upgrade trunion, need some input about my build please
thank you from someone that is still learning, or should i say a new be tryin to wean my self of the mothers tit, thanks but wait 2k that dont sound as bad as spending 18k for a Long block an having to think twice about runnin her the way she she was meant to be drivin in gm hand book(ha ha ha )thanks anyway. rich
There's nothing wrong with the stock rockers. They've worked fine for over a decade in other LS engines, albeit at a 1.7 ratio instead of 1.8
Given all the guide wear discussion, there is a theory that a roller tipped rocker is better for the valve guides, but there is really no hard evidence of that and as long as guide wear is monitored there is really no risk of destruction.
The downside of the roller tipped rocker is that the aluminum ones have a history of breakage and most of them are effectively heaver than the stock items.
I just got back from my test drive after installing the comp cams trunion upgrade. My car has 4k miles on it. Previously was nice and quiet at startup, but once the oil got warm it sounded like a sewing machine. Now it's the same level of quiet from cold startup to warm. Glad I did it.
I run Yella Terra 1.8 shafts. Love them...no complaints. Quiet and functional. Over 10K miles on them now. Plus, you can have them for around 600 bucks. Yes, they are an upgrade...depending on who you listen to.
