C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] For the folks who don't run the run flat tires..
Old 06-02-2014, 04:44 AM
Kouasupra
Kouasupra's Avatar
Default For the folks who don't run the run flat tires..
Do ya'll carry a can of "fix-a-flat"? (I know it's not recommended for TPMS) Or a small air compression with a patch kit. Going to be picking up a set of Michelin PSS and I'm curious.
Old 06-02-2014, 07:52 AM
Jet Stream Blue Z06
Jet Stream Blue Z06's Avatar
I have the PSS (345's for the back). I love them. I have a compressor and patch kit that fits in the small storage compartment in the trunk.
Good luck.
Old 06-02-2014, 08:34 AM
LEJ ZO6
LEJ ZO6's Avatar
I just carry our AAA card.
I've got rid of the run flats on every Corvette I've owned and never worried about carrying a patch kit or compressor. The only time I have had a flat was when a wheel casting cracked and I lost the air out of the right rear tire. I filled the tire the best I could, drove to the nearest Chevy dealer and had the wheel replaced.
If you keep your tires in good repair not having a spare is no big deal.
Old 06-02-2014, 08:58 AM
Michael_D
Michael_D's Avatar
Good luck.
That's what I do. Have not had to plug a hole yet..... Hopefully I won't. Now that I've said that, I will.
Old 06-02-2014, 09:38 AM
RFZ
RFZ's Avatar
Good luck.
what size on front?
Old 06-02-2014, 09:47 AM
RedZ4me
RedZ4me's Avatar
several mini compressors on the market, and add a plug kit. both fit in the rear cubby storage
Old 06-02-2014, 11:21 AM
dmuellenberg
dmuellenberg's Avatar
I also carry a patch kit and mini air compressor but have not had to use them yet (almost 50k on my non run flats). I did pick up a razor blade on a trip last weekend which caused a slow leak but I was able to get home and get it fixed.
Old 06-02-2014, 11:24 AM
racerx3317
racerx3317's Avatar
I have both. Patching would be plan A and the can of fix a flat is plan B. The one I have says it's TPMS safe and hopefully I never find out.
Old 06-02-2014, 12:00 PM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,708 Likes on 1,088 Posts
Small air compressor and a plug kit. In 27K miles and three sets of tires over a 5 year period, I only had to use it one time. Took all of five minutes.
Side note, my 2003 C5 Z06 came from the factory without runflats (as did all C5 Z06s).
Old 06-02-2014, 12:10 PM
Jet Stream Blue Z06
Originally Posted by rfz
what size on front?
285/35
Old 06-02-2014, 04:25 PM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
Aaa
Old 06-02-2014, 04:28 PM
LFZ
LFZ's Avatar
I carry a Walmart $19.99 fix a flat kit w/ compressor. It says it's TPMS safe.
Old 06-02-2014, 08:02 PM
blkbrd69
blkbrd69's Avatar
There is no safe TPMS safe tire fix a flat, if its liquid and plugs it kills. Found out the hard way.
Even the nice Continental tire kit will kill TPMS, but it sure is handy.
A plug kit and inflater works well if you can get to it to plug, can be a challenge depending on where you are.
I carry a plug kit and the Contental kit, can use the inflater without the sealant can or both depending on what you need.
If I have a flat, its OK to me if I write off a tpms when I fix it.
Another thing, its a royal PITA to clean sealant out of a tire to do a proper mushroom plug after fix a flat. Don't be surprised when a shop complains, charges an extra fee and then you have to buy a TPMS. was still cheaper than replacing a runflat. Easy to pull a temporary plug and do a proper repair.
Old 06-03-2014, 01:25 AM
Kouasupra
Kouasupra's Avatar
Air compressor and patch kit it is..
Old 06-03-2014, 01:46 AM
Adam_W
Adam_W's Avatar
If you travel in or near a city, then just
1) your cell phone,
2) AAA card,
3) and address/phone of your trusted tire guy who won't scratch your wheels.
Even with a run flat, you'd opt to have it towed, as driving any significant distance on a run flat will make it unrepairable.
Old 06-03-2014, 02:18 AM
Kouasupra
Kouasupra's Avatar
I have full coverage with State Farm. I have too good tow coverage, but if your stuck nearby a really bad area. I doubt you want to wait for that tow truck.
Old 06-03-2014, 03:40 AM
LMB-Z
LMB-Z's Avatar
Air compressor and plug kit. Picked up 2 screws a few days apart from each other. I was lucky. Went out to get in the car and had a flat (both times). Took tire off car, carried to tire shop, fixed from inside, put back on car.
To For the folks who don't run the run flat tires..
Old 06-03-2014, 04:08 AM
meanjoe
meanjoe's Avatar
Plug kit, small air compressor, AAA card.
The only time run flats are good is when they're flat.
Old 06-09-2014, 05:49 PM
coletrickle
coletrickle's Avatar
Default Not that simple
I keep my car in perfect condition, I just inspected my tires and brakes. Live in the middle of nowhere and was in the middle of nowhere and picked up a screw that bled me flat in 1 min. I have/had runflats. I couldn't find ANY tire dealer that would patch a runflat. Had to order two new tires and here's the rub...tire guys said you can patch a non run flat but then wouldn't suggest high speeds because of the patch.
So what's the deal. I agree on AAA, compressor and non RFT if you live in a town, but if you are like me in BFE, you pick up one screw and its $1000 down the drain?!?!? I see the continental kit and inflators and the patch kits, but if the speed rating or reliability is screwed, what's the point of non runflats??
I really don't see a win either way! Any comments or suggestions??
Old 06-09-2014, 06:06 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
When I was running non run flats, I carried the Continental Tire kit (ContiComfortKit) as well.
Along with:
1. Two different sizes of standard type plug kits, in case of a hole which would not plug with a smaller size kit. I also carried a Dynaplug kit.
2. A pair of needle nosed pliers and a flat head screwdriver for removal of any screws or nails,
3. Road flairs, Maglight flashlight, and a small roll up tarp.
I have had to make two daytime roadside repairs by plugging a tire which was on the ground, and depending upon where the puncture is, and your ability to get to it, it's not always easy.
Had it been dark and on a tight two lane road with little shoulder, it would have been near impossible, and certainly dangerous.
My first option was always to attempt to plug the tire as opposed to using the goop if possible, for the reasons above already stated.
But in the conditions I mention above, darkness, narrow road, I would opt for the goop and not worry about the TPMS.
Quick Reply: [Z06] For the folks who don't run the run flat tires..
