[Z06] fluids question
fluids question
question to every one about brand and type of oils and fluids they use in their cars? I know it may be subjective. is it best to go with mobil1 like manual says for the engine? or would something like royal purple or??? be better? what about the trans.and diff.? brand and weight? clutch and brake? coolant? and engine oil filter, a/c delco, wix, royal purple, mobil1?
You have to be very careful here.
First, for the differential use only the GM fluid. Do not expect your GM dealer to know what that fluid is... you can look up the correct p/number here on the forum. This is what I run.
For the transmission, if you are just going to drive it on the street I would also use the GM fluid. This is also what I run but if I get access to transmission temp on the track I might switch, cautiously, to a non-GM synthetic. If you expect to run the car hard (track) I have heard you might get by using the proper Mobil 1 (there is more than one, this Dexron thing is confusing) or maybe Amsoil.
For the engine, on paper Amsoil is the best oil, pretty much hands down. If you're poor, try Mobil 1 0-40 (WalMart). I run Redline 5-30 on the street, with a mix of 10-40 for the track. I wouldn't mess with any of the other 'exotics', don't know much and haven't seen much data on them (I don't buy/use on testimonials/advertising).
I forget which oil filter had the tightest media... maybe the Mobil 1. Any of the major brands should be fine (Wix, K&N, GM, etc -- most of them are made by the same company).
Coolant, you have little choice -- you have to use the Dexcool.
Brakes, for the street Prestone DOT 4 from WalMart. For the track, bring your Gold Card (I use Motul 600 which isn't too bad on price).
Use the brake fluid in the clutch. Don't forget to flush that using the Ranger method (I don't go the 30 pump hardcore route, but at least suck out the dirty stuff).
Power steering I use Redline ATF, but that is for heat issues on the track. For the street use whatever GM approves.
Most important, be aware that all fluids are not alike. There is transmission fluid that will wreck your transmission, there is differential fluid that will wreck your differential. Pay close attention to certifications and classifications on the bottle if you deviate from stock. RTFM. Do not go by what some AutoZone or GM counter person tells you.
if the gm fluids are are considered as a top choice I am ok with that, Is it best to just go down to the local dealer to get it all, or order it online somewhere? also what part#'s do I ask for? are there any additives needed? trans? diff?
Local Dealer. Check out the DIY sticky at the top of this forum on how to, it also includes the GM part numbers. On your 2009 on the dif you will find the lower cooler connection (which is also the drain) only comes out part way before hitting the rear crossmenber, but you will be able to hold it against the crossmenber and drain out all the old fluid. Don't lose the clip.
P/N 88861800, Manual Transmission and Transfer Case Fluid
P/N 88862624, DEXRON LS Gear Oil 75W-90 Additives are already in it, don't add more.
These fluids are not cheap, but you don't need to change them often (24 track hours per OM).
In my 09 I use M1 0W-40 Euro formula motor oil from HPDE's, you will see 235* water temp and 285* oil temp with your '09. I also use Motul RBF 600 for the brakes and cheap Prestone DOT 4 for the clutch. If you do hard HPDE's and change to aftermarket brake pads you will see very high front rotor/pad/caliper temps. I got rid of my brake cooling problem by installing 4" brake ducts from the sides of the grill.
For the motor oil I personally run Rotella T6 10w40 w/ STP oil treatment and use the AC Delco gold or platinum (forgot what it was called) oil filter. The oil filter can only be purchased from the dealer at is around $17.00 I will have to dig around for the receipt for the p/n.
Received 8,930 Likes
For vehicles that see heavy track use GM started recommending changing the diff fluid after 24 hours of track usage starting in 2009. Other than that all of the other recommendations are the same.
I use all GM recommended fluids. The transmission fluid has never been changed. Car is 7 years old with 37K miles on it and the trans shifts smoothly with no issues. The engine dropped a valve 3.5 years ago at 24K miles so the replacement only has 13K miles on it.
I use Pentosin Super DOT 4 brake and clutch fluid in the clutch (GM recommended) and Wilwood 600+ in the brake system. The Wilwood fluid is a DOT3 compatible fluid but has a much higher dry boiling point than most other fluids.
If I need to add oil at a track event I will add Mobil 1 0W40.
Bill
Premium Supporting Vendor
I may be perceived as biases as I sell AMSOIL, but been using it in all my cars include my 02 Z06 at the track since 2004.
If you'd like to try AMSOIL for any of your fluids (and they have engine oil, filter, tranny, diff, power steering, and brake/clutch fluid for the C6 Z06), more than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
