C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] install ls9 oil pump
Old 03-12-2015, 07:16 PM
Dplenzig
Dplenzig's Avatar
Default install ls9 oil pump
I had to remove the pump while changing the cam to get to the tensioner. How do you install the pump without ruining the gasket??
Old 03-13-2015, 02:25 AM
Tim Taylor
Tim Taylor's Avatar
First of all : did you change to a different style of tensioner? I am asking because i did while installing am cam. The dogbone tensioner has thicker bolts which will Lift the pump a tenth of a Millimeter away from the Block. Really dangerous because you will loose Oil pressure.
Regarding the pump: once removed carefully grind a small radius on the bottom where the sharp edges are. That way the pump slides in smoothly and is easier to uninstall in the Future as well.
Quick Reply: [ZR1] install ls9 oil pump
