C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Fast 102 vs MSD airforce comparison.
Old 04-07-2015, 09:00 AM
  #41
Michael_D
Michael_D's Avatar
Originally Posted by [Cerberus]
If you want to run the OE with the fast you need their extensions correct? Aside from that everything is the same? Thinking I was doing a good thing I got the fast fuel rail kit and when it showed up it just looked like a stock rail with injector extensions.
With the FAST, you can't run the LS7 fuel rail, no matter what spacers or injectors you use. You have to either run a LS2 fuel rail, or aftermarket fuel rails. And regardless of rails used, you need to either use spacers, or go with taller, LS2 style injectors. In that regards, the MSD makes it a simpler, less costly swap out from the OEM intake.
Old 04-07-2015, 09:13 AM
  #42
shane p
shane p's Avatar
I don't know for sure but it looks like fast has ls7 fuel rails so you can use the shorter injectors without the spacers.
Old 04-07-2015, 09:14 AM
  #43
shane p
shane p's Avatar
At least I hope so because that's what I bought .
Old 04-07-2015, 10:44 AM
  #44
atljar
atljar's Avatar
Fast will not work with Ls7 rails.
You need LS2 rails and injector spacers.
Old 04-07-2015, 10:59 AM
  #45
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,111 Likes on 589 Posts
Old 04-07-2015, 11:27 AM
  #46
x88
x88's Avatar
Thanks for posting this! Seems like going from OEM intake to MSD is the clear choice for me. Being the skeptic I am, I'll prob wait to see some results from stock to MSD before pulling the trigger. I was told with my H/C setup I'd see 25 from the fast, so if that's 30-35 with MSD I'd be very happy!
Old 04-07-2015, 12:14 PM
  #47
Michael_D
Michael_D's Avatar
Well you should probably just call them and ask to verify…. But, I believe the LS7 OE rail they sell for this intake is actually an OEM LS2 rail that they buy from GM, then just give it a new name. But even with the LS2 rail, the shorty LS7 style injectors will still need spacers. Or, get taller LS2 style injectors.
If you take a look at the front of the LS2 and LS7 intakes, all this will become clearer. The LS7 intake (OEM) does not have the same profile as the LS2. The LS7 is flatter. The FAST intake was originally designed for the LS2, and when they started making the LS7 intake, they did not completely redesign their product, but simply modified their LS2 intake to fit the LS7 cylinder heads. Well, that and some mild runner changes.
Old 04-07-2015, 12:22 PM
  #48
[Cerberus]
[Cerberus]'s Avatar
This was the information I was missing, it looked like an Oem ls7 part but I wasn't able to put them side by side.
Old 04-07-2015, 12:46 PM
  #49
shane p
shane p's Avatar
I was referring to the fast ls7 billet rails, aftermarket not the factory rail.
Old 04-07-2015, 01:00 PM
  #50
reasonable suspicion
reasonable suspicion's Avatar
Im running the Katech fuel rails made by FAST for the ls7 and have no spacers.
Old 04-07-2015, 01:50 PM
  #51
shane p
shane p's Avatar
Ok, thanks that's what I was hoping.
Old 04-07-2015, 02:54 PM
  #52
this is what I have....dunno if it helps you
https://www.corvetteforum.com/forums...xr-intake.html
Old 04-07-2015, 02:59 PM
  #53
shane p
shane p's Avatar
That is what I got, thanks
Old 04-07-2015, 04:03 PM
  #54
Michael_D
Michael_D's Avatar
Sorry for adding confusion.... I forgot the FAST billet rails worked with the shorty injectors.
Old 04-07-2015, 07:58 PM
  #55
The Highlander
The Highlander's Avatar
Ryne is right.... leaner will not yield anymore power anyways... 9whp is what i actually expected.... i would put it in.. maybe in the porting there is an additional 5.
If the fast was ported before, the gains are awesome.
Old 04-08-2015, 07:23 AM
  #56
Da Z06
Da Z06's Avatar
Way to hijack the thread with this fuel rail discussion.
Old 04-08-2015, 02:04 PM
  #57
redbird555
redbird555's Avatar
Why are people thinking they're going to bolt this on an see 10hp over a fast 102 instantly? Look at the build and the graph; it gained for 500 rpm and was only making 8hp from that for a tiny window towards the end.
The ls7 in this build is likely easily exceeding 600-675 hp. If it took all that to see a gain of 8hp do you really think that you'll see that with a bolt on ls7 or even one with stock heads? I see CMS corrected the fueling concern but still how do you lose .5 afr reading at the tail? If they were the same at the header then they should be pretty close at the tail pipe seeing as its the same car.
I have neither intake but some people here get so absorbed in the tiny improvement it had for 300 rpm on a serious build like this, that its unrealistic. If you have a mild build there's no downside for either intake both will likely make the same power.
To Fast 102 vs MSD airforce comparison.
Old 04-08-2015, 02:11 PM
  #58
C6Z06C6
C6Z06C6's Avatar
That is some of the dumbest sh*t I have read in a while. You obviously don't have any idea what you are talking about.
Old 04-08-2015, 02:52 PM
  #59
djfury05
djfury05's Avatar
Originally Posted by C6Z06C6
That is some of the dumbest sh*t I have read in a while. You obviously do no idea what you are talking about.
Agreed.. a great way to look at things.. take one example and apply it to all scenarios.
Old 04-11-2015, 09:57 AM
  #60
0Rob@ChampionMotors
Former Vendor
Rob@ChampionMotors's Avatar
https://www.corvetteforum.com/forums...s7-intake.html
Quick Reply: [Z06] Fast 102 vs MSD airforce comparison.
