[Z06] The Best Performance Engine & Trans Mounts on the Market @ Hinson Motorsports
C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
We know you will be putting the car in the air when installing these so we have a solution to keep you from damaging your Corvette while it's on the lift or jack. Check them out. Brand new lift pads. These will work on any model of C5 or C6 and just pop into place on the rocker rail under the edge of the car on the jacking/lift points. When you need them pop them in and when your done take them out. No modifications what so ever needed to be done to the car. Pick them up in sets of 2 for home, or sets of 4 for a lift.
