C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Launch Control
Old Apr 20, 2015 | 08:54 AM
ZO6Vette's Avatar
ZO6Vette
Default Launch Control
After my fiasco at the strip with bogging every time, I researched launch control. I now know how to engage it, but I have a question. Does it matter which competitive mode you use? My understanding is that launch control disengages traction control and keeps the active handling. Some of the competitive modes say that they disengage these things. Does the launch control setting over ride whatever the competitive mode dictates?
Old Apr 20, 2015 | 08:31 PM
Victory07's Avatar
Victory07
Any competitive mode. Doesn't matter.
And don't be surprised if using launch control makes your times even worse.
Old Apr 20, 2015 | 09:58 PM
Dave Schotz's Avatar
Dave Schotz
You also do not have to floor the car and dump the clutch.
You can actually put in any mode (I prefer 5) and come out from an idle (if you wanted) and then floor the car, and it would control wheelslip by only pulling spark and fuel.
It's pretty cool to be honest, but quickest times will be by doing a "healthy" burnout prior to pulling up to the line and having all nannies turned everything off.
Good luck!
Dave
Old Apr 21, 2015 | 09:56 AM
ZO6Vette's Avatar
ZO6Vette
Dave
I don't have a problem with wheel spin. In fact I need some wheel spin. My problem is the car wants to bog in ALL the competitive modes and even if I don't use them and just turn off traction control. The result was the same; BOG. My best sixty foot time was using competitive mode 3, but it wasn't consistent. I don't know what I did different when I got that 2.086 sixty foot time. The other sixty foot times were 2.3-2.4. This with drag radials. They worked great when I tried them on a deserted street in the canyon. The wheels spun for about fifteen feet and hooked. I thought the strip would be even better. Maybe I need to raise the rpm's to around 4K like the launch control does and that might work. It could be I'm not giving it enough rpm to launch those massive 345 drag radials.
Old Apr 26, 2015 | 07:30 PM
c5racr1's Avatar
c5racr1
On a prepped drag strip with a heated drag radial that is a 345, yea bout 4-4500 and release the clutch while pushing the throttle to the floor and hold on.
To Launch Control
