[Z06] power steering cooler help - heads/cam install
Does anyone have a pic of proper routing for the factory power steering cooler lines?
I cant seem to route the line that goes from the cooler to the to the reservoir. I cant believe this is what is holding me up from finishing this swap.
Just finish my head, cam, exhaust swap. The picture above is pretty good example of how the line routes.
The biggest pain I had was bolting the pump back into the bracket. Make sure to get all the pump to bracket bolts started before you tighten up the bracket to the head! And before that make sure you put the bracket to head bolts in their respective
holes before you install the pump!
there's a plastic "clip" that goes around the rack and captures one of the lines somewhere -somehow.
Do you have a picture of where that round clip goes and what line it grabs? looks like it might be at the edge of your picture on the passenger side.
I struggled with the lines too, got everything back together and it looks right, but that clip is sitting on a shelf, don't know where it goes.
Hope this helps!
