C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Anyone running Non-titanium ls7 intake valves?
Old 05-30-2015, 07:44 AM
blacklist
blacklist's Avatar
Default Anyone running Non-titanium ls7 intake valves?
This is a long shot here. I was wondering if anyone has switched out their oem stock titanium intake valves for a set of Manley stainless valves or any other non-oem brand? If you did, why?
I bought a set of LS7 z06 heads and the guy before me swapped out the titanium intake valves from stainless Manley. I'm weary, but think I will still be okay To run them.
Old 05-30-2015, 01:07 PM
Z06Ronald
Z06Ronald's Avatar
Why would one switch to heavier valves?
Old 05-30-2015, 02:08 PM
blacklist
blacklist's Avatar
Ha I will never understand why either...
Old 05-30-2015, 03:04 PM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
I know several people who are running SS intake valves. No issues. Mostly because they came with the aftermarket heads (Mast 305s). They make anywhere from 1000-1450rwhp, rev to 7k and have no issues. The valve must be paired with the correct spring and cam, but can be used just fine depending on application.
Old 05-31-2015, 01:36 AM
blacklist
blacklist's Avatar
Those guys that are running stainless, I'm assuming they're running valve lash caps? I know Manley also makes ls7 extended length ones that delete your valve lash cap.
Old 05-31-2015, 12:01 PM
Blackonblacksls
Blackonblacksls's Avatar
Stainless valves don't need lash caps.
I run stainless valves with a bigger spring than you could fit on a stock head paired with shaft mount rockers.
This is what I felt would be the most durable setup on an big lift cammed ls7..
To Anyone running Non-titanium ls7 intake valves?
Quick Reply: [Z06] Anyone running Non-titanium ls7 intake valves?
