C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Help with locating 3/4" y fittings.
Old 09-18-2015, 07:47 PM
KENS80V
KENS80V's Avatar
Default Help with locating 3/4" y fittings.
I'm about to weld up my modified intercooler coolant manifold as shown in the first picture. Can anyone suggest a source for the 3/4" Y fittings as shown in the middle of the second picture? (I borrowed the second picture from the recent RKT Performance for sale thread)
Old 09-19-2015, 08:20 AM
Texasthunder
Support Corvetteforum!
Texasthunder's Avatar
Default Y fitting
Grainger has the plastic 3/4" Y
Old 09-19-2015, 02:06 PM
ZBADESTZ@Straightline
ZBADESTZ@Straightline's Avatar
X2
Man that setup looks familiar...
You should of left your bleeders on there.
Old 09-19-2015, 02:15 PM
KENS80V
KENS80V's Avatar
Thanks for the tips. I browsed the Grainger online catalog and couldn't find them. Can anybody supply a part number for them?
My LS9 will be going in a mid engine kit car. The intercooler reservoir tank will be higher than the bricks so I thought I wouldn't need the bleeders in that location.
Old 09-19-2015, 02:24 PM
Texasthunder
Default Fittings
Grainger Part #23CM51 and 23CM52
Jegs also has them but not much info. on them. Part # 065-34102
Old 09-19-2015, 02:49 PM
http://m.ebay.com/itm/TRACKER-3-4-INCH-PVC-Y-CONNECTOR-BOAT-HOSE-FITTING-/200565518420?nav=SEARCH
Old 09-19-2015, 05:21 PM
KENS80V
KENS80V's Avatar
Thanks for the leads. Think I'll go with the AC Delco #34102 (also known as #88909496). Available at Jegs and Summit.
It is glass reinforced Nylon. Good to 480 degrees. Made for use in the auto industry.
Old 09-19-2015, 06:59 PM
KENS80V
KENS80V's Avatar
Originally Posted by ZBADESTZ@Straightline
Personally I wouldn't use PVC for automotive use.
On another note I'll be sending my new bricks to you soon for the plate mod. Can you pm me the details/cost.
To Help with locating 3/4" y fittings.
Quick Reply: [ZR1] Help with locating 3/4" y fittings.
