C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] ZR1 'chittering' noise when pulling away from stop
Old 03-15-2016, 05:32 PM
2013ZR1
2013ZR1's Avatar
Default ZR1 'chittering' noise when pulling away from stop
I recently bought a '13 ZR1 with about 17,000 miles.
Whenever I pull away from a complete stop, and the engine lugs down a little, it makes sort of chittering, squeaking noise, almost sounds like a squeaky exhaust pipe hanger or maybe an intake noise.
Makes this sound either as clutch pedal is part the way out, or all of the way out. I've also heard it if the engine lugs down in a higher gear. Not that I make a habit out of it!
I'm hoping this is completely normal and wondering if it might be the supercharger bypass valve chattering.
Otherwise this car runs great, amazing really.
Old 03-16-2016, 10:13 AM
ZR1Cat
ZR1Cat's Avatar
Congrats on your new acquisition.
I've got about 9k miles on my 2012 and I haven't heard or experienced any such issue. Perhaps the other owners will chime in soon and provide you with a more helpful response.
2013ZR1 (03-16-2016)
Old 03-16-2016, 10:30 AM
whatcop?
whatcop?'s Avatar
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
It is normal. It is drivetrain lash or play. Basically its clutch chatter except coming from the transmission. Sometimes swapping to a better fluid helps to get rid of the noise or just don't let rpms drop too low. I recommend Royal Purple ATF transmission fluid if you are going to do a swap.
2013ZR1 (03-17-2016)
Old 03-17-2016, 05:30 PM
mirage2991
mirage2991's Avatar
indeed, clutch chatter. I've notice mine goes away after an HPDE week-end...ya know when you get it to "operating" temps LOL...
Old 03-17-2016, 07:48 PM
nolimits
nolimits's Avatar
You can get this from valved mufflers when they start going loose internally from heat cycles. I've had two C6s get a minor rattleish sound on moving forward from a stop. Also during any lugging which causes more vibration. Noise progressed to all the time. Muff replacement cured it in both cases. But if you track it the heat cycles usually get to new mufflers also especially with mods, headers, etc which increase temps back there.
Old 03-18-2016, 01:56 PM
2013ZR1
2013ZR1's Avatar
Thank you. Makes sense.
Old 03-18-2016, 07:11 PM
GMJim
GMJim's Avatar
I have a 2011 and a friend has a 2010 and they both do this. Almost sounds like a bird chirping under the hood. Enjoy your new car!
Old 03-19-2016, 09:41 AM
2013ZR1
2013ZR1's Avatar
Thanks! That's what I was hoping to hear.
I appreciate all of the responses.
To ZR1 'chittering' noise when pulling away from stop
Quick Reply: [ZR1] ZR1 'chittering' noise when pulling away from stop
