[ZR1] Forgestar F14 19 fronts 18 rears on ZR1 Anyone has this setup?
i like the Forgestar F14 but I also want 18 inch rear wheels for my 345 MT drag radials. do you think it will look awkward with 19x10 inch wheels in front and 18x12 rears? i can go with 18s all around if i choose the Forgestar CF5 but i like the F14 better. What you guys think? Anyone done it before? Does the option of going with 19 inch F14s all around sound better? But then will I get as good of traction from the Nitto NT05R 345/30/19, that i would get from the 345/35/18 MTs? Help me out bros.. running about 735 whp..
whiteghostZR1 (03-22-2016)
i think you just solved my problem then. I think i will just go with the 18inch Forgestar CF5 all around. I will have more choice on the tires i can put on, wether its drag or road course. what tire size do you recommend on the front with the 345/35/18 MT on back?
NYOverlord (03-24-2016)
Personally I run Hankook V12 275/35/18 with them. The 19" NT05R setup is ok and good for stock to ~600whp but the 18s just hook much better when u get to either of our power levels
Are you sure that 345/35/18s are the correct size for these wheels?
Where can I get Mickey Thompson E/T Streets from? Most places like Jegs are saying they no longer have any in stock in those sizes because Mickey Thompson is ending production of those and promoting their new SS model line which isn't as sticky, but ok to drive in rain.
i'm bout to order them too
http://www.jegs.com/i/Mickey-Thompso...oductId=753925
I'll finally be ready to put down 1200rwhp!!
By the way, should I get tire pressure monitor sensors for these rims as well, considering they'll have Mickey Thompson drag radials on them?
I have a Pro EFI 128 stand alone ECO and boost-by-mph set up, so I don't even know if I should run the 1/2 roll race events with traction control on or off...
Maybe the 18" cf5 will work but now I need to
Also stagger 19" in front with my 18" f14 rear or go to the cf5
Did you have a problem with the front brakes or rear brakes?
PK Auto Design (03-18-2017)
