[Z06] Best reasonably priced stereo/speaker upgrades
So this is a multi part question that I need your help with. I have a 2007 Z06 with a Bose system/NAV, etc. rear speakers are starting to crackle at decent volume. So that is the first thing I want to address.
Secondly-the door speakers/tweeters-what are they best that you guys have used?
Thirdly-want to add a new NAV with Bluetooth and iPhone connectivity/siriusXM
Fourth-maybe a JL Audio 10 or 12 inch sub. Need amp(s) to power all speakers.
Fifth-have 2 other things I need to address-I have a really annoying rattle in my drivers side door. How do I fix? Also am missing the 2 little screws that hold the plastic under halo cover in place which are just above the passenger and driver head area??
Thanks in advance
Thanks in advance
All kinds of good information over in the Audio/Electronics subforum...https://www.corvetteforum.com/forums...lectronics-20/
I started a thread over there a while ago, asking for help. I'm in the process of putting the car back together now. The sound deadening part was a real PITA..... I still need to do the trunk, but it should be easier than the cabin. After I get'r all done, I'll add pictures and notes and a shopping list. I did not go overboard on speakers and electronics. Middle of the road. Morrel speakers, Kenwood electronics, a corner sub.
I went with some budget stuff on my speakers, I already had a 10in JL W3 sub in the car. Front speakers I replaced with kicker 11KS652 6.5in components, rear speakers got kicker 40CS54 5.25in. I have a 5 channel rockford fosgate punch amp powering it all. For the head unit I put in a Kenwood DDX9702S it has bluetooth, hd radio, and android auto. Probably spent less than $1000 on everything, I did the installation myself, I have no complaints with any of the speakers or the head unit.
How'd you route 12v power to the amp? I'm trying to figure out how to route it from the bat, to the in line fuse block, then to a 1 by 2 distribution block (for 2amps behind the seats). I'd like the fuse to be easily accessible, but hidden.
Whew, so I was half right. The trunk was easier than the cab, but still a PITA. Wire routing time now.
I posted in Audio forum and have had 1 response. I post here and there is far more interest. I used to use MB Quartz in most of my cars in the past, but I have been looking at JL Audio components. Wish list would be a Kenwood Headunit, rear cam, JL stealthbox, JL Audio components, JL amps. I already have a Billet Tech 170 amp alternator, so good to go with power.
I had intended to buy Focal components, based on reviews praising their sound quality. After a conversation with Dennis (Double D Mods), went with the Morel components for the doors and their basic speakers for rear "fill" sound. He also has a 10" corner sub that is less costly than the JL. Figured I'd try it. For amps, I went with the Kenwood D class 5 channel, and will run it bridged for the fronts and the sub. I bought a second, lower grade A/B Kenwood 2 channel for the rears. The Kenwood HU I got has the larger screen, Bluetooth, usb inputs, nav and a rear camera. Sound proofing is a combination of foil backed butyl, self adhesive foam, and MLV on the floor. It's been a labor of love thing. A lit more work than I had anticipated. Hopefully, I'll finish next weekend.
Quick question for you. Did you retain the stock gps antenna, or use the one supplied with the hu? Oh, and did you have clearance issues with the trim plate? Mine is catching when the door opens and closes. I need to remove the hu to adjust the trim, and that would be a good time to swap out antennas. I hate installing or removing the console.
Michael_D (04-25-2016)
