C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] For Z owners with Headers......have you had starter problems ??
Old 09-06-2016, 12:08 AM
wjrive
wjrive's Avatar
Default For Z owners with Headers......have you had starter problems ??
If no problems with having to replace a starter, What kind of headers do you have ?
My problem is, I keep having starter problems , because my ( Pfadt ) Headers sit to close to my starter. I plan to buy a different set of headers.
Which brand of 1-7/8"headers are the easiest to install and will leave room to install a blanket over the starter or will have the clearance needed for a Heavy duty MSD type starter ?
Thanks all
Willie
Old 09-06-2016, 12:37 AM
zeeohspit
zeeohspit's Avatar
I have had my American racing headers for two years without any problems. They were surprisingly easy to install. They are close to the starter but last time I had to remove the headers to do my heads I decided to heat wrap the starter just for insurance.
Old 09-06-2016, 01:10 AM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
I have Pfadt 1 7/8" headers with no starter problems, but the headers were ceramic coated. Between that and the EE ceramic coated tunnel plate with insulation and my catted x-pipe, the interior tunnel and console run cooler than OEM.
Old 09-06-2016, 02:07 AM
User Omega
User Omega's Avatar
I've had the ARH headers and catted X for ~6k now. No issues.
Old 09-06-2016, 02:10 AM
LMB-Z
LMB-Z's Avatar
I have AR long tubes...no coating and no wrapping. 3 yrs, 12k miles and no problems...yet.
Old 09-06-2016, 02:14 AM
phipp85
phipp85's Avatar
1.875" American Racing Headers. No starter replacements but I did have the headers and X pipe coated.
What do you mean by starter issues? What is the car doing?
Old 09-06-2016, 02:47 AM
User Omega
User Omega's Avatar
The starter solenoid overheats and then fails. Some even melt the posts out. The car will not crank. Most people just combat the problem by shielding the starter.
Old 09-06-2016, 07:36 AM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
Kooks headers, 105,000 miles on them without any issues with the unprotected starter.
z06clif (09-21-2016)
Old 09-06-2016, 07:49 AM
encasedmetal
encasedmetal's Avatar
kooks here and no problems. knock on wood...
Old 09-06-2016, 08:23 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Zero starter issues. Still OEM stater. Had LG 1 7/8" and ARH 2" on the car. Unprotected starter, no issues at all.
SteveDoten@ARH (09-06-2016)
Old 09-07-2016, 03:50 PM
wjrive
wjrive's Avatar
AZDave47 , did you have your Pfadt's and your tunnel covers installed at the same time ?
User Omega hinted what might be closer to the cause of my periodic starter problems.
Willie
Old 09-07-2016, 05:58 PM
AzDave47
AzDave47's Avatar
Willie
Yes they went in when I had my HCIE work done, including DeWitts and McLeod RXT 1000 clutch.
Old 09-09-2016, 04:41 AM
C 5
No Time!
C 5's Avatar
Starter #5 here. I'm suspecting there is more of an issue than the heat. For some reason my car seems to have crazy under hood temperatures. Something is causing it to get hotter than I ever remember. I know for a fact I have no exhaust leaks to begin with. Ive checked everything over. Couple months ago I wrapped a portion of my headers (the area thats the closest to the starter) and the starter wires, and the car does not have nearly as much of a starting issue, unless its very hot out and its a hot start. I suspect the issue is more within the wiring. My car has had 1 7/8 Kooks and for the first 65k miles it started right up, every single time, not a single issue, than couple thousand miles later (within 6k) miles I've replaced 4 starters. 3 oem/reman and 1 MSD. My theory is the factory heat shielding on the starter wires deteriorated and went out, I know it did for me anyhow, and then after the car gets some heat in it, i.e driving in traffic, it would have so much resistance in the wires that it kills the solenoids in the starters. Thats my opinion on it, only other possible thing is something causing the car to generate so much heat that its wreaking the wiring and taking out the starters. Anyway thats what ended up "fixing it" for me. I dont know how long this one is going to last for, but I suspect its not forever. FWIW I have compared the tables of the stock tune and my current tune in HPT and nothing related to starting has been altered, no timing, no fueling, cranking, or anything else was altered. But the car is definitely very very hot under the hood now.
Old 09-09-2016, 09:40 AM
Must_Have_Z
Must_Have_Z's Avatar
1-7/8 Kooks. Fairly easy install. Good fitment. I had them ceramic coated. Unprotected starter. No issues for over a year now.
Old 09-09-2016, 12:21 PM
rio95
rio95's Avatar
1 7/8" ARH and no issues. Have 10-15k miles on them.
Old 09-10-2016, 08:53 PM
mtomlin1
mtomlin1's Avatar
This was my problem, wires exposed and had a hot start problem.
Old 09-10-2016, 08:55 PM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Pfadt...no issues
To For Z owners with Headers......have you had starter problems ??
Old 09-10-2016, 09:07 PM
1fastC3
1fastC3's Avatar
ARH 1 7/8 headers, no issues, 25k miles and 18 months of all season driving.
Old 09-11-2016, 08:29 AM
Rusty-
Rusty-'s Avatar
Kooks 1"7/8
Old 09-11-2016, 02:52 PM
rabrooks
rabrooks's Avatar
I have the LG super pro headers, no coatings or wraps, with high flow cats., I am on starter #2 and the third one is on the horizon as this one is starting to drag. 14,000 miles on the headers
Quick Reply: [Z06] For Z owners with Headers......have you had starter problems ??
