[Z06] ZR1 wheels 50mm offset with spacer?
found some zr1 wheels with drag radials.. But it has a 50mm offset..think i need 36mm.. Could i add a spacer to correct it? Would that be safe with less threads on studs with spacer?
Generally, I'm never a fan of spacers...but many run them just fine. I would never recommend running spacers without longer studs. I know some have also opted for extended thread lug nuts, but again that would only be good/safe for just so much IMO.
Since you need to make up 14mm, you cant use slip on spacers on stock studs. You'd need to replace the studs for extended/longer sets. Most you can use on stock studs are about 1/4" or 7-8mm before you run out of useable threads.
