[Z06] 2009 Z06 Battery drain/charging system issues
Hi everyone,
I'm hoping someone can help me pin point a weird electrical issue that I am having with my '09 Z06.
The battery voltage is not stable. Sometimes when I'm driving I see the voltage on that dash of the battery at 14V, which it should be and then sometimes it drops down to about 11.9V! Yes, the car is running when this happens! Two weeks ago, I took the car out and it died on me as the voltage at the battery kept going lower and lower until the car shut down on me.
Things I have done:
-Changed the battery to an AutoCraft one.
-Changed the alternator to an AutoZone Duralast one. Had the same issues so I returned it and put the old GM one back on.
When the card died on me, I had it towed to the dealership and they replaced the alternator with a OEM GM one. As soon as I got home from the dealership, I turned the car off and when I tried to push to start I heard a click (This is what used to happen before the dealership attempted to fix it). I pushed it again and I heard the engine try to turn over and then it finally started. I checked the battery voltage and it was at 11.9 volts idle. So same problem exists even with the new GM $700 alternator.
I am beginning to think it is a bad ground at the starter or the starter itself could be junk. Anyone have any thought? If any more info. is needed or there are any questions please ask!
Thanks and have a great day!
Things I have done:
I'm not sure if it is the same electrical problem that I had, but here is the related post that you can take a look at
https://www.corvetteforum.com/forums/c6-tech-performance/3858288-interesting-intermittent-start-issue.html
https://www.corvetteforum.com/forums...art-issue.html
The one thing that keeps cropping up is the issue with bad wiring at or around the starter. Yesterday, I tried to start my car and it would not start at all. I heard the solenoid click every time but the starter did not have enough voltage to turn. When I checked the battery voltage it was 11.5V. Something is drawing current from the battery and dragging the voltage down in my case.
My car's issue was mostly a starting issue, but because the pin in the hood fuse box was fried, it also occasionally had some hesitation / stalling when driving over bumps
it doesn't take much to take the hood fuse box and take a look. If you read up on this issue, many people replaced all sorts of parts before they fixed / found the issue.
IIRC if starter wiring/solenoid is burned, intermittent starting & strange charging system behavior results.
Get car in the air & give starter, connections & solenoid a thorough inspection, use a flashlight. Any heat damage should be clearly visible.
FYI: a knowledgeable member posted a DIY tutorial on a repair procedure for bad/burned out solenoid w/o replacing entire starter in case your problem's only a bad solenoid.
Good deal less $ vs. replacing starter & solenoid. G/L
Before replacing any parts. I would check:
1) All grounds, wiring to the battery
2) Starter wiring, solenoid
3) Check alternator and wiring
It is also possible your alternator is getting heat soaked. I had this happen on my z06. Had to wrap the alternator and new starter wiring. But mine is modified running ARH headers.
Have a qualified shop look at it.
