[Z06] 10.44@129.9mph bolt ons stock clutch RECORD
Loll, thank you sir for kind of words
Sometimes, the stock clutch acting up a little and its hard to feel, but it slip enought through the entire run and the mp/h drop a bit. 134 mp/h is no joke. Is good for 10.1x to 10.2x. The limiting factor, as you know is the stock clutch in you're quest for 10.0 to 9.9x .
Best of luck and keep us updated
Seb
Seb
Sébast19X (12-01-2016)
Awesome pass
Supporting Vendor
St. Jude Donor '09
Hi
I constantly frequent this forum but rarely do i post. I give credit to those who has helped me on my quest to prove that a stock ls7 clutch can produce low 1.52 60ft with over 130 quarter mile passes 50k miles and counting.
Huge thanks to Gary Hilden for providing all the bolt on parts from his personal c6 z06 a proven and documented 9 second combo. To Doug at ecs for fine tuning drivability, to Brandon at crazy house customs for dyno tuning and track analysis.
Mod list
ARH headers
Custom halltech mf103
Ported fast 102 manifold
Ported stock throttlebody
Catch can
Stock ls7 clutch 50k miles
Stock npp mufflers
carbon racing seat removed passenger seat
315 hoosiers on c5z wheels
mustang dyno tuned @475rwhp sae corrected
Mod list
ARH headers
Catch can
Stock npp mufflers
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
Have u logged the map at wot? I have a Halltech and can't seem to get better than 94-96 KPA at WOT and it decreases with RPM. I can't help but think this is leaving power on the table. I have mine installed just as Halltech recommends.
Unfortunately i do not have map data. My tuner compensated for the extra air in high rpms added more fuel. I do have surging with the direct path due to map turbulance but once its full throttle at the track it switches to wot table.
Nice driving....maybe ill see over there atco again in the spring......i just picked up a rps bc2 used with some meat on it for 600...i have 300 runs on my stock clutch with 585rw and best 60foot was 160 on street tires not even my drags lol.....my clutch is finished...u pump it alot as you rolling to light right? Willwood 660?......keep going...
You are getting cooler air but air is still be sucked rather then forced....i will make 4in y pipe off throttle body to two 3in hose run to the front of the car hooked onto heater vent 3in round to 2in x6 in plastic secured if front to see if i can get some forced , cold air in...
#34
My first mod to the car was an lg intake and "canned" tune from doug ecs did i ran 10.8s consistenly with that. after the mods, crazy house customs did a full dyno tune and track analysis confirming that i was leaning out up top added more fuel and timing. Went back to doug for some part throttle drivability issues an easy fix for him.
#35
#37
Drag racing at its finest, nice run. What is your launch technique?
#40
