[Z06] New GSpeed bolt in C5/C6 Tilton Master cylinder setup
Supporting Vendor
For years, there has been a need for a real race car master cylinder setup. In the past, we have retrofitted floor mount pedals ( lots of fab, and driver position must change) or hanging pedals ( again, lots of fab, and need for dash bracing that not all have)
We recently were approached to build another floor mount pedal assembly, and while the customer was perfectly happy paying the 6500$+ price tag, it didnt make business sense to us.
Enter our OEM replacement master cylinder setup.
Using the stock brake pedal assembly and stock mounting points, this system is literally bolt up, build lines, attach bias ****, and go racing.
Its designed to work with racecars and high performance street and track cars.
We installed the prototype today in a customer's car. The factory ABS system is deleted, and lines are plumbed directly from the Tilton master cylinders to the OEM hardlines.
Of course, we tested it on track, and it works great. Pedal effort is higher, as you'd imagine, but very easy to modulate and control.
Pricing is currently set at $4200, but if we get enough interest we could do a Group Buy and lower the price.
Currently have a few kits on the shelf. Price is 4200, fully loaded with masters, reservoir, mounts and balance bar assembly.
Please call or email to place an order.
https://gspeed.com/product/corvette-...ke-conversion/
- Saves 2lbs over stock
- Nearly unlimited master cylinder sizes
- Uses Tilton Pivot master cylinder with factory adjusted bleed port
- OEM bolt in, no modifications necessary
- pedal rod adjustable to change pedal height
- booster assembly no longer needed
- fully bias adjustable from inside cockpit (location and brand up to end user. Note: Bias adjustment not possible with OEM ABS system due to factory plumbing layout)
- Integrated reservoir assembly, includes clutch reservoir as well
- Adjustable pedal ratios (4.7:1, 5.5:1, 6.2:1) enable the brake pedal to be tuned to driver preference without having to change master cylinder bore size.
- Sealed bearings used throughout.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
Supporting Vendor
Yes, the pictures are a little misleading. There is actually more room than the OEM setup.
Supporting Vendor
