[Z06] bolt size help
bolt size help
changing the heads out on my 08c6z and lost the bolt that goes into the back of the head on pass side for wire loom. anybody have idea what size that bolt is so i can go get another?
It's probably a M10 x 1.5. I'll try to verify later today. Lowes, tractor supply, fastenal, Ace hardware, etc any of those will carry it. Low grade 8.8 class or whatever is cheapest will work fine it's not doing anything that requires any kind of strength
Also needs to be fairly short like 12 mm or 16 mm long.
