[Z06] Half shafts replacement which is best?
I heard that the 06-07 half shafts are ****. And I was looking into a 2009+ z06 half shafts they use it in the zr1s also I see them as being the strongest are the 08s fine as well? And what about c5 z06.
Thanks couldn't find a forum that would answer this!
You can not use the half shaft from a 2009-2013 unless you have those years. The outer bearing spline in the back is 33 spline the 2006-2008 are 30 spline. The bearings are not interchangeable either. You can either do the C5 or the newer version C6 for your year car as they have updated those.
He has 750whp and with slicks and beats it and holds up. I think I'm sold to that.
[QUOTE=Patriot Six;1594278077]I don't track it much, but I have seen others with more power than me using them for hard launches. For the price, you can't go wrong.[/
Yeah I'm not worried about breaking axles I'm worried about when it breaks it breaks my diff
