[Z06] Nitron Racing Shocks C5/C6 Race Pro Coil Over Kit
Former Vendor
St. Jude Donor '13
Our engineers here at XP Motorsports have worked very closely with the Nitron engineers to develop a product designed to maximize the true potential of the Corvette. The combined engineering staff have worked countless hours to bring you the very best coil-over suspension for your c5/c6. These coil-over have been extensively tested on one of our C6 ZO6 at Sebring International Raceway known as the toughest track on equipment especially suspension components for the last 8 months without a failure or compromise. They have performed flawlessly for countless hours and laps. This Nitron equipped car is currently leading the points in NASA Florida Region TT1 & TTU along with setting fastest laps at numerous events.
So when you are ready to step up and make your Corvette handle and ride the way it should then turn to XP Motorsports & Nitron for your suspension components.
Not quite ready for the top of the line race/high performance setup. Then look at the Nitron
R1 Fast Road Shock Kit (non coil over)
R1 Club Sport Coil Over Kit
R3 Club Sport Coil Over Kit
http://www.xplosiveperformance.com/N...it_p_4178.html
Need more info call 888.493.8041
Former Vendor
St. Jude Donor '13
Former Vendor
St. Jude Donor '13
Nitron has been at the forefront of motorsport suspension technology since 1998. Founded by Guy Evans, the Oxfordshire-based company has gone from strength to strength, producing winning shocks for customers all over the world. Nitron benefits from a design team with an accumulated experience covering machining, materials technology, hydraulics, Sports Cars, GT Racing, WTCC and F1 racing. Many even have experience as competitive drivers themselves. The ability to draw upon such a wealth of knowledge provides Nitron with an insight into the industry that very few can compete against.
3-Way independent damping adjustment. By incorporating our class leading large diameter piston and ultra-strong piston rod, the R3 system demonstrates outstanding levels of performance, damping control and adjustment. Remotely mounted reservoir allows quick and simple independent adjustment of rebound and fast and slow compression damping.
The large range of adjustment and quality of feedback allows the experienced driver to fully exploit the full potential of their car. The R3 is a proven race winner and lap record holder across a wide spectrum of international motorsport formulas.
The high-grade materials protect against corrosion whilst reducing weight. Every R3 kit is custom built, sprung and fully serviceable. Titanium and hard-anodized parts are hand built to last not only season after season, but also the harshest of U.S. winters.
Tubes- Nitron tubes are cold drawn multiple times for maximum stiffness and strength, before being honed, hard anodized, and then roller burnished for a precision surface designed to last.
Rods- Rod shafts are Teflon coated and made to Moto-X spec, the best there is, period. All the main structural threads are rolled in (not cut in) removing stress points.
Valves- all valve components are machined from super-hard stainless steel-which means they will last a lifetime, literally
World class compression adjuster- Nitron shocks have the widest range of useful adjustment available on any mono tube gas shock
C5/C6 R3 Race Pro Coil Over Kit
The NTR R3 system sets the standard for ultimate performance with a design that offers drivers and engineers unparalleled damping control.3-Way independent damping adjustment. By incorporating our class leading large diameter piston and ultra-strong piston rod, the R3 system demonstrates outstanding levels of performance, damping control and adjustment. Remotely mounted reservoir allows quick and simple independent adjustment of rebound and fast and slow compression damping.
Former Vendor
St. Jude Donor '13
#33
Former Vendor
St. Jude Donor '13
When you become serious about making your Corvette handle. The NTR R3 system sets the standard for ultimate performance with a design that offers drivers and engineers unparalleled damping control.
#34
Former Vendor
St. Jude Donor '13
Another set going on a 09 ZO6!!! So when you become serious about making your Corvette handle. The Nitron R3 Race Pro system sets the standard for ultimate performance with a design that offers drivers and engineers unparalleled damping control.
#35
Former Vendor
St. Jude Donor '13
Nitron Race Pro R3 coil-over’s installed on a Corvette ZO6 in NASA TT1 trim DESTROYS SEBRING INTERNATIONAL RACEWAY TRACK RECORD by 2 second.
Are you ready to make your Corvette handle the way it is suppose to. http://www.xplosiveperformance.com/Nitron-Corvette-C5C6-Race-Pro-Coil-Over-Kit_p_4178.html
#36
Former Vendor
St. Jude Donor '13
#37
What are the spring rates on the R1?
Do you guys dyno the shocks like PFADT does to make sure the shocks and springs are working in a consistent, linear manner?
#38
Former Vendor
St. Jude Donor '13
Since the Nitron Shocks and coil-overs are born from racing technology all coil-overs are dyno tested and tuned. Spring rates are optional depending on what you plan to do with the car. One size does not fit all.
