[Z06] F-2 Prochargered C6 Z06 | RPM (Pics & Video)
427, All Pro Heads, Precision Metal Craft Intake, F2 Procharger and Holley EFI.
Some video of it coming together in one of our Episodes.
PUMP GAS Numbers Check back soon for when we tune it on race gas and do a new video!
Big numbers !!!
I would consider 12.2 afr at WOT lean on a blower car (reading from where it looks like the throttle was let off). any blower car I've had has been in the mid 11's afr wise. please correct me if I'm wrong though.
I posted in the other thread but are you running a 60mm gate and is it working well? I run a 44mm gate with my F1x car but even with a 14lb spring I still am seeing 23.5lbs by 7700 rpm (on wastegate pressure). I may have to switch to a 60 or add another 44
Awesome build guys
Awesome build guys
It goes to about 12.2 for a bout 3-400 rpm. I dont feel thats unsafe for the dyno. For a 1/4 mile pull or something yes its a tad lean but as long as timing is safe etc its not lean enough to hurt anything.
Awesome build guys
Awesome build guys
Nice pumpgas power!
For the HCI car, is the smoking caused by blow by or head gasket?
Cog
Can you point me in the direction to getting one of those belts ?? I’m blowing belts on my cog set up f2 like there’s no tomorrow just ordered a sprag I️ need a source for good belts .. thanx!!
