C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] American Racing 2" Header Weight ?
Old 04-18-2017, 11:28 AM
I brake for nothing
I brake for nothing's Avatar
Default American Racing 2" Header Weight ?
Anybody know what these weight or can weight a set ? AR does not know or care to find out.
Old 04-18-2017, 01:20 PM
lt1z
lt1z's Avatar
less then manifolds and cats
Old 04-18-2017, 03:14 PM
JShort
JShort's Avatar
Here is some information from the C6 Z06 "weight" sticky:
OEM Headers/Mid section/cats------> 74.5 lbs
OEM Headers/Mid section/cats------>LG SuperProLongtubes 1 7/8 + X Pipe wo/cats (-27 lbs)
OEM Headers/Mid section/cats------>B&B Headers 1 7/8+X Pipe wo/Cats 57lbs (-23.52lbs)
OEM Headers/Mid section/cats-----> Kooks 1 7/8 w/cats(-55lbs) (-10.6lbs)
OEM Headers/Mid section/cats------>B&B Headers 1 7/8+X Pipe w/Cats 62lbs (-3.6lbs)
OEM Headers/Mid section/cats-----> LG Super ProLongtube 1 7/8 + X Pipe w/cats ??
OEM Headers/Mid section/cats------>American Racing 1 7/8 w/cats(-??)
OEM Headers/Mid section/cats------> Melrose SF06RZ Long Tube Headers Exhaust System (+4.4lbs)
It's probably safe to say that the American Racing 2" headers will be within 10% of the LG or Kooks numbers above (depending on if you will be using cats or not).
Not exact, but should be pretty close.
I brake for nothing (04-18-2017)
Old 04-18-2017, 03:29 PM
jft69z
Support Corvetteforum!
jft69z's Avatar
I have a set of ARH 1 7/8" sitting on my bench & can weight them later tonight. Also have the catless X & pipes to weight as well.
EDIT: just found this on the Z06 page mentioned above- post # 364
I just weighed my American Racing 1 7/8 longtube headers without cats and it came in at 49 lbs.
The headers were 24.5 lbs and the offroad X-pipe was also 24.5 lbs.
Old 04-18-2017, 05:15 PM
I brake for nothing
About 25 Lbs off the nose. Not too bad
To American Racing 2" Header Weight ?
Quick Reply: [ZR1] American Racing 2" Header Weight ?
