[Z06] Different Brands of Wheel Bearings and Quality
Greetings guys... I have diagnosed what seems to be a bad rear wheel bearing/spindle on my 07 Z.
I know the idea is to always stick with Delco/OEM units, however in searching I have found Centric and Moog both make a unit for our cars.
I used Centric components on my previous Cobra in the past and was happy with their parts. Moog is also a fairly established Mfr as well. I have all Moog parts to rebuild the front end on my daily and hands down looks like top notch quality.
The parts I've found are:
Centric 402.62026E:https://www.summitracing.com/parts/c...model/corvette
Moog 512442:
Any thoughts? Thanks!
Moog 512442:
The only SKF unit I've been able to find is a competition/race unit that is close to $400 each. That would be out of my price range.
I should say that I'm considering the Centric/Moog units as they are cheaper than OEM.
Street only car, I'd use Moog and you'll never know the difference from OEM. If you plan to auto-x or do track days, then SKF.
Moog has a solid reputation...probably what I'd go with in your shoes.
SKF rears are available at rockauto.com for $120. Part# BR930198
The following 2 users liked this post by atljar:
63Corvette (06-08-2017),
no cigar (05-09-2017)
Wasn't able to find these on rock auto but did find on ebay for $117 shipped. SKF units.
They work very nicely. Turns out the drivers side rear was shot but I replaced the pair. May consider doing the front as well at some point. The hardest part was breaking loose the lower ball joints.
Considering these 3, as they are all about the same price. The Timken's have the shortest warranty, no sure if that even matters.
Timken: https://www.rockauto.com/en/moreinfo...1433663&jsn=22
SKF: https://www.rockauto.com/en/moreinfo...1433663&jsn=27
Moog: https://www.rockauto.com/en/moreinfo...&jsn=26&jsn=26
That I saw, there was no difference in quality. The only thing I didn't really like about the SKF's, if I remember correctly, was that the clips for the ABS sensors were not a good fit on their brackets. The MOOGs clipped right on. Minor headache but I'd go with the MOOG if I had to do it again.
I should also say that the SKFs are also rusting rather quickly.
JaredW (03-18-2019)
