C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Clutch slave line burnt!
Old 06-26-2017, 09:47 PM
Roddy Ponton
Cruising
Roddy Ponton's Avatar
Default Clutch slave line burnt!
So is it possible to take of this section of hose right before the the metal tubing and get a metal braided wire?? I've searched and asked but cant seem to find a straight answer. disregard the red circle
Old 06-26-2017, 10:01 PM
Roddy Ponton
Cruising
actually. it doesn't look to come apart... well, time to drop the trans.
Old 06-26-2017, 11:42 PM
J504
J504's Avatar
https://www.corvetteforum.com/forums...-line-diy.html
You're welcome
rjacobs (06-27-2017)
Old 06-27-2017, 02:03 AM
rjacobs
rjacobs's Avatar
Originally Posted by J504
I did exactly this when mine blew. I put double layer of heat shield on the braided line. I had to buy 10" line as that was the shortest non-custom the shop sold. 10" is plenty, 8" would be better I think.
Clutch pedal is MUCH smoother. Mine always seemed to be hard to press at the top of the throw initially, now its smooth all the way through the throw.
Old 06-27-2017, 01:33 PM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,228 Likes on 775 Posts
did it burn on some aftermarket headers? if so can i guess hinson?
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old 06-27-2017, 08:42 PM
butch353
butch353's Avatar
We had the same deal an went with 4mm tubing an Swedgelock Unions to get around that deal an we had hinson headers. took some tight welding to make the fittings but got it done an like the previous post alot better clutch feel. jd.
Old 07-09-2017, 07:38 AM
Roddy Ponton
Cruising
it hit my texas speed long-tubes. I couldn't see it from the top i had to get under the car. I just ended up getting a whole new slave with metal braided lines and a new clutch and flywheel setup because I had to drop the trans-axle.
To Clutch slave line burnt!
Quick Reply: Clutch slave line burnt!
