[Z06] 5 Year/15K miles maintenance?
'12 Z06 - bought recently
1. Condenser/radiator picked up a huge amount of crap as I drove it home from the dealership 1300 miles away. AC started smelling literally like pee for first 10/15 seconds in the morning. So took it to the dealer - had them change oil and cabin filter, clean out the craps. Will see if it helps with the smell. Did anyone have a similar issue with the AC air smell?
2. Also changed air filter
3. I'd have declined the fuel induction service if I was first owner. So did that too - their service dept. did great jobs in the past. But I am a little confused about 'premium EFI kit' in the service details. The idle throttle definitely improved. But what's this EFI thing anyway?
4. Of course, they always mess with the PSI - 32 (still great for 100F+ day). On my way home, as the PSI reached 35, the ride got 'very' bumpy, was scared to take the high speed turn at 5 over the limit, dropped about 2 psi - it was great again! Michelin PSS - is there any way it could have flat spots as it's been sitting with the new tires for about a year and a half or any other suspension component to check? I never had issues with GYs/Pirellis with turning at 10/15+ mph with 2+ PSIs in the Camaro SS's I had before.
5. Did the ranger method already.
If anything else is recommended based on vehicle age, please let me know. Trying to get it right from the beginning, but I'm still not 100% happy at the turns. Thanks!
Brake fluid flush.
Coolant flush and new T-stat.
I also did the trans and rear diff when my '09 hit 4 yrs old and had ~12K miles.
schecter7 (07-24-2017)
I'm @ 54K on my '08, just had coolant, rear end flushed/filled + oil change done.
Knew Master Cylinder's under recall & would be replaced w/ upgraded improved version if I told 'em my clutch felt 'odd'.
They replaced it under GM's warranty, not my GMEPP and I'm sure when work was done a flush & refill was performed on brake system also.
Now fresh fluids all-around & presently waiting for my nose to return to its normal length.
Given you're only at 15K, sounds like all the important stuff's been covered. Only thing left is to enjoy.
