[ZR1] Did 2013 ZR1's X pipe have Cats???
Trying to find correct X-Pipe for 2013 ZR-1, is this part/casting number correct for 2013 Z? When did they start putting cats on ZR1 x pipes?
GM20968756
GM20968756
Received 1,346 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
Extra cats are on the 12 and 13 models. If you're buying go with the Corsa 14331 x-pipe with no cats. Your console won't get nearly as hot plus a few hp and a little better sound.
^ This. Unless of course you're returning a car to stock to sell.
Here's what I come up with: https://www.gmpartsdirect.com/oem-pa...YtMmwtdjgtZ2Fz
I know the illustration doesn't show cats on the pipe...but you can clearly see it only fits 12/13 models (and its regularly priced at ~$830, which would suggest cats as well).
Never mind, found my answer. I did not know that this existed, good to know!
https://www.corvetteforum.com/forums...-two-cats.html
BigVette427 (10-05-2017)
I haven't found another one yet, and the Corsa can be had for like $415 through the right vendor. B&B makes an x-pipe but it's only for 2009-11 models. I asked them and they said it will not fit 12-13s (I have a '13).
TripleBlackZ06 (12-11-2017)
Corsa is the only mid-pipe I've seen to eliminate the aft cats on 12/13 models.
Does anyone know what the Corsa catless pipe weighs? I think the OEM pipe with cats is around 40lbs and the titanium x-pipe from Akrapovic that only fits the 09-11 models only weighs something like 9 or 11 lbs.
Good guess would be ~20lbs. I think the OE catless "H" mid-pipe from my '09 was 19-20 lbs.
