Pfadt 1 7/8" vs ARH 2" dyno results
Some of you may have remembered my CPR HCI build last year. Main mods from stock were Pfadt 1 7/8" headers w/catted x-pipe, WCCH redone heads, Katech K501 cam and cleaned up MSD intake. Link to the full build below. I have had quite good results on several performance events with that build including in 1/2 mile roll race trap speed (800'elev.) and 1-mile standing start trap speed at 6500' elevation.
The results of that build were interesting with 602 rwhp @ 7100 rpm and low 489 rwtq using SAE smoothing 0. After the build I got many comments about the headers contributing to the odd results. I decided to have CPR replace the AFE/Pfadt headers/catted x-pipe with ARH 2" headers and catted x-pipe. In addition, to create a little more headroom on the fuel side CPR installed ID 725 injectors.
My goal was to pick up torque in the 5000-6000 rpm range and keep my power but drop it down into the 6700 rpm range. That should help me in my goal to break 200 MPH at Mojave in the 1 1/2 mile standing start event, hopefully next spring.
Keep in mind these are on 91 octane gas with a 91 octane tune by NicD.
A scan of the dyno runs CPR did this week are below"
The comparison of the changes on this dyno (different from the dyno last year) show a very good increase in torque and a reasonable increase in power and at a lower 6700 RPM, just what I was looking for. On last year's dyno the 602 SAE smoothing 0 would be 595 SAE smoothing 5.
When I get the dyno files I will overlay the plots from last year's dyno on these CPR dyno runs.
Here is Cordes Facebook post on the runs:
and the link to my build last year: https://www.corvetteforum.com/forums...sd-intake.html
Facebook Post
Congrats on the results Dave. I followed CPR on fb and saw the post earlier today.
This is really great data to showcase the difference between the headers, since there weren't any other changes affecting power production.
That low speed torque is just killing the tri-y design!
HC Mechanic (04-28-2019)
HC Mechanic (12-28-2017)
Good stuff...thanks for posting.
I didn't know that was you there dropping it off or I would have said hi. I have the base dyno run on my camera.
Joe said the arh fit a lot better than the other headers. This backs up what I've seen time and time again. That the pfadt make 15-25 less than a solid 4-1.
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Very impressive results Dave! That dyno curve is simply fantastic. Should really prove now that a better set of 2" headers does in fact make a measurable difference, with the right supporting mods. You are twisting about the same torque as me over the same portion of the band, but with more power. And I'm on 93 octane. I'd really like to know your dynamic compression ratio. I assume your bottom end is stock? Much thanks to posting. I'd be interested in your results on the track. The kind with turns.
Road circuit results will have to be seat of the pants type as I do not often time laps with the Z. I do know the last couple of times I had it our, both stock and after the CPR build that my now 3 year old R888s did not hook as well as before even though they have not been heavily heat cycled. I have been able to hand time laps from my videos
You also have to think it was a hair cooler for the 10am Pfadt run, than the 5:30pm ARH run the next day. I would love to see this same comparison on a FBO ZR1.
J88L98IROCZ (01-14-2020)
That's more like it !!!! Excellent results, Dave
Exactly what I see time and time again. ARH 2" is the way to go. Kind of funny too since the entire marketing behind those trick Ys is that they make better low end and midrange power.
Thank you for sharing, great gains!
My prior build thread was on a different dyno and was SAE Smoothing 0. When I get the dyno run files from CPR I will do a few other dyno graphs that will compare the two different dynos and log them as SAE smoothing 5. The HCI w/ Pfadt were run on both dynos, primary difference was 6K miles on the build on the latest run on CPR dyno.
All dyno runs were with my normal 91 octane gas.
The following 2 users liked this post by AzDave47:
HC Mechanic (04-28-2019),
STANG KILLA SS (10-05-2017)
