C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] MMS 265 build. 640rwhp/542rwtq N/A pump gas 91 octane.
Old 11-05-2017, 01:48 AM
ALTRDTA
ALTRDTA's Avatar
Default MMS 265 build. 640rwhp/542rwtq N/A pump gas 91 octane.
Just wrapped up a build for a friend/customer using Tony Mamo aka Mamo Motorsports complete top end kit. Build is as follows-
MMS 265cc ported heads
MMS Stage 3.5 comp cam
Manton custom length pushrods
Johnson short travel lifters
MMS spec Yella Terra roller rockers
Ati under drive balancer
Msd intake manifold ported by MMS
Nick Williams 102mm tb
American racing 2" headers w/catted x pipe.
Corsa carbon fiber cai
52lb injectors
Rps carbon twin disc clutch also modified by Mamo motorsports.
This car (as far as I know) has the highest hp naturally aspirated of any c6 z06 in Utah with a factory bottom end. 640rwhp/542tq. These dyno pulls were on 91 octane pump gas, with no additives and no meth. I'm extremely happy with how this car turned out. A big thanks goes out to Tony from Mamo Motorsports for all the pieces, and all the tech advice. He was right there throughout the process answering questions and following up on progress from beginning to end. He's a top notch person to work with and his products work.
Modified slave
Old 11-05-2017, 01:24 AM
Navy Blue 210
Navy Blue 210's Avatar
Congratulations!
Outstanding Results, As Usual with MMS LS7 Top End Package.
ALTRDTA (11-05-2017)
Old 11-05-2017, 01:35 AM
ALTRDTA
ALTRDTA's Avatar
HC Mechanic (12-18-2017)
Old 11-05-2017, 01:56 AM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Dayum....not a fan of that CAI, but damn fine results from that combo!
The following 2 users liked this post by MTPZ06:
ALTRDTA (11-05-2017), HC Mechanic (12-18-2017)
Old 11-05-2017, 04:58 AM
User Omega
User Omega's Avatar
Very impressive results!
Old 11-05-2017, 07:34 AM
double06
double06's Avatar
Nice run, good results. Looks like AF ratio is about 12 to 1 in the upper RPMs. Hard to tell from chart.
Old 11-05-2017, 08:43 AM
Whis9
Whis9's Avatar
Awesome #’s
Old 11-05-2017, 09:06 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Great work as always Dan and Heath.
Old 11-05-2017, 09:07 AM
FNBADAZ06
FNBADAZ06's Avatar
Bad *** !!!
Old 11-05-2017, 09:08 AM
FlyingJay
Navigator
FlyingJay's Avatar
I've seen a 454 Stroker LS7 make similar numbers. Impressive.
How does it drive?
Old 11-05-2017, 10:18 AM
ALTRDTA
ALTRDTA's Avatar
How does it drive?
I haven't driven it since the tune, but the customer is happy. The tuner said it had a little cam surge, but that's to be expected for the most part.
Old 11-05-2017, 11:01 AM
95vettski
95vettski's Avatar
Amazing results!
Do you know the exact specs of the cam?
Old 11-05-2017, 11:07 AM
Turbo2L
Turbo2L's Avatar
Cam specs?
Old 11-05-2017, 11:35 AM
Brandon619
Brandon619's Avatar
You can’t go wrong with Mamo Motorsports.
Old 11-05-2017, 12:12 PM
Lorenzo Serra
Lorenzo Serra's Avatar
Very impressive! Well done guys.
Old 11-05-2017, 12:24 PM
Josh B.
Josh B.'s Avatar
Very impressive results! The BC2 I sent you was a real beauty, I'm in talks with Tony on a modified version for my car.
Old 11-05-2017, 12:51 PM
TRSCobra
TRSCobra's Avatar
Awesome results! About time that Bane427 car got the love it deserves!
To MMS 265 build. 640rwhp/542rwtq N/A pump gas 91 octane.
Old 11-05-2017, 03:18 PM
AzDave47
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
Very nice, especially on 91
Old 11-05-2017, 04:03 PM
lt1z
lt1z's Avatar
1.18 CF damn. Uncorrected must have been around 545whp which explains why 91 had no issue given the altitude it must have been at to end up with SAE 1.18. Stock injectors too.
Old 11-05-2017, 04:16 PM
sprinter
sprinter's Avatar
640 rwhp... 91 octane... hmm
Quick Reply: [Z06] MMS 265 build. 640rwhp/542rwtq N/A pump gas 91 octane.
