C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Ls7 with a ls9 supercharger best of both worlds
Old 02-07-2018, 08:33 PM
427V8BB
427V8BB's Avatar
Default Ls7 with a ls9 supercharger best of both worlds
http://www.superchevy.com/how-to/eng...-past-1000-hp/
looking at this article and I am very interested anyone have any cons on this? I’m need a whole new 427 cause mine popped a piston so I’m going forged. Should I take on this project? I’d be happy with 800-850crank hp on 91
Old 02-07-2018, 08:57 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
This combo doesn't make any sense to me.. They tossed out all the high-perfomance stuff that makes an LS7 unique and special, then you are left with thin sleeves that are not-well suited for those power levels..
On the other hand, you could be the guy that can say "my engine cost more to build than your whole car".
If you want an LS9, just buy an LS9, for a fraction of the cost...
427V8BB (02-07-2018)
Old 02-07-2018, 08:59 PM
427V8BB
427V8BB's Avatar
If you want an LS9, just buy an LS9..
its a z06 I need the displacement atleast I think the sleeves were redone all they changed for power wise was the heads other than the aftermarket cam and ls9 blower
Old 02-07-2018, 09:12 PM
Dan_the_C5_Man
So, LS9 heads, blower, front assembly, non-LS7 pistons, rods, crank, oil pump AND an inferior block / casting.. I don't get it..
Old 02-07-2018, 09:22 PM
Neumonic2002
Neumonic2002's Avatar
St. Jude Donor '09-'10
Seems interesting, if your already completely replacing the rotating assembly and replacing the factory problematic LS7 heads I say go for it!
Old 02-07-2018, 09:29 PM
427V8BB
427V8BB's Avatar
well not completely, I’m doing a 5.3 bored out to a 4.125 and stroked for a 427 guy told me the block has done many 1000-1500hp cars includes they’re own sleeves for the power. Than I’m also getting a new crank rods and pistons anyways. Why not slap on a ls9 accessory, supercharger, and heads and call it a ls8 lol technically not a ls7 but 427 cubed LS and I can add piston squirters
ill reuse my dry sump
Old 02-07-2018, 09:30 PM
427V8BB
427V8BB's Avatar
i have AHP stage 4 race ported heads milled .030 with btr 660 springs and those racing guides he sells still have the receipt. It’s the top notch ls7 head he sells only 2k miles on them! Easily 3-4K I can buy a set of used ls9 heads for a grand then the rest is for the accessory and blower!
Old 02-07-2018, 09:54 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
There's almost nothing LS7 about that build.
Old 02-07-2018, 10:04 PM
MTPZ06
MTPZ06's Avatar
Just pull the BTR cam for a blower cam, and go with a TVS 2300 like you initially thought, sell off the Mamo MSD. I'd just be careful on the tune since you have milled heads. No need to reinvent the wheel and try to mate a LS9 blower to the car. Or go back to stock intake, blower cam, and a Centri unit.
Old 02-07-2018, 10:12 PM
427V8BB
427V8BB's Avatar
the block might not be salvageable dunno yet, if it is then it’s almost as much to do sleeves and pistons for 6k might as well do the fully forged 5.3 for 7-8k and slap either ls7 or ls9 heads for a tvs. Money wise it’s looking cheaper and more reliable to do the 5.3 with a ls9 top end swap. It not being a ls7 doesn’t bother me guy said it still spins 7200rpms long as it’s more cubes than a 426 doesn’t bother me originalality doesn’t matter at this point car is fully modded and has a cage lol
Old 02-07-2018, 10:15 PM
427V8BB
427V8BB's Avatar
was as thinking about that centri and stock intake hmmm what do you think is the most reliable and budget wise so I can get it done faster. Thinking the 5.3 bored and stroked with the ls9 top end still
Old 02-07-2018, 10:37 PM
MTPZ06
MTPZ06's Avatar
5.3 block like you're doing, your heads, swap your stock cam (or find a mild blower cam) and OE intake manifold back on, and find a used centri kit.
Old 02-08-2018, 08:27 AM
Tonylmiller
Tonylmiller's Avatar
Why not just buy a ZR1 and modify it? I think you can get that much power without too much trouble. But I could be wrong.
Old 02-08-2018, 08:59 AM
427V8BB
427V8BB's Avatar
i cant sell my z with a bad piston I’m already to deep into this car
Old 02-08-2018, 10:41 AM
Tech
Tech's Avatar
Sleeved 5.3L (btw, you can't "bore" a 5.3L to 4.125" without replacing sleeves) with your stock crank, rods and new pistons will do 800 hp all day with an A&A or ECS centri kit.
The following 2 users liked this post by Tech:
427V8BB (02-08-2018), DOUG @ ECS (02-09-2018)
Old 02-08-2018, 11:01 AM
427V8BB
427V8BB's Avatar
RED said the rods can’t handle boosted power it can handle 800 NA not boosted so I guess I need to go fully forged for 800whp?
Old 02-08-2018, 11:16 AM
Tech
Tech's Avatar
Nope. They can. Several people here have done it. Nobody really fails the LS7 Ti rods.
RED won't assemble your shortblock anyway. Talk to HPR. They can get you a resleeved 5.3L and use your stock LS7 parts (if they are still salvageable).
To Ls7 with a ls9 supercharger best of both worlds
Old 02-08-2018, 11:22 AM
427V8BB
427V8BB's Avatar
If I can use my rods and crank how much you think this is gonna run me for a short block? Thanks for the help tech and why do you guys want centri so bad? Curious thought the top mount was better and cooler
Old 02-08-2018, 11:41 AM
Tech
Tech's Avatar
If you think that, you should spend a whole lot more time reading.
Old 02-08-2018, 11:45 AM
nuke61
nuke61's Avatar
I think the first question to answer is, what's your budget?
Quick Reply: Ls7 with a ls9 supercharger best of both worlds
