C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Horn HONKS when I unlock
Old 03-17-2018, 04:39 PM
Gboras
6th Gear
Gboras's Avatar
Default Horn HONKS when I unlock
How in the world do I turn this obnoxious function off. This is something new. Probably started after I replaced the battery. This isn’t a short beep. It is a full on HONK!
2010 ZR1
Help!
Old 03-17-2018, 05:11 PM
LMB-Z
LMB-Z's Avatar
I think you can turn that function off in the DIC. Replacing the battery probably reset everything, so go back and recheck all of your settings.
Old 03-17-2018, 06:35 PM
EVRose
EVRose's Avatar
The horn should not sound at all when unlocking the car. That isn't even an option. Only when locking can you set it to sound the horn or not.
When this happens how do you get it to stop?
Also, no settings are lost when the battery is disconnected.
Old 03-17-2018, 11:12 PM
Gboras
6th Gear
Gboras's Avatar
Default Stupid horn
The horn sounds full on for about a second and a half then stops. It sounds both if I unlock with the fob and/or with the door handle only. I’ve had the car since new and this behavior is recent.
Old 03-18-2018, 12:53 PM
EVRose
EVRose's Avatar
Is it just one honk or multiple? Almost sounds like the alarm is being activated since there is no built in honk on unlock function.
Old 03-18-2018, 01:25 PM
Gboras
6th Gear
Gboras's Avatar
Default Unlock honk
It is one horn blast. The entire car is stock with no aftermarket items whatsoever.
Old 03-18-2018, 02:22 PM
EVRose
EVRose's Avatar
Sorry but I can't imagine what it could be.
Old 03-19-2018, 08:34 AM
itomh
itomh's Avatar
My 08Z did that a couple of times a few weeks ago and has not done it since. I was really embarrassing......nothing like going to unlock your car and a girl walks by and your horn goes off, as if to say look at me, this happened twice. I couldn't find anything in the settings that would have caused it, just glad it stopped.
Old 03-19-2018, 10:03 AM
Gboras
6th Gear
Gboras's Avatar
Default Horn
Lucky you! It is driving me absolutely nuts. Last week my wife brought it in for its annual inspection. Like something out of Benny Hill, when the mechanic opened the door, the horn sounded causing the mechanic in the next bay to jump and smack his head on the hood of the car he was working on!
Old 03-19-2018, 10:20 AM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
There's the problem right there.... You let your wife drive it.. It has to be her fault.
Old 03-19-2018, 10:39 AM
EVRose
EVRose's Avatar
Try posting this problem in the C6 General forum. A lot of guys there that might not look here may be able to help out.
Gboras (03-19-2018)
Old 03-19-2018, 10:41 AM
Gboras
6th Gear
Gboras's Avatar
Point taken.
Old 03-19-2018, 05:30 PM
Dirty Howie
Dirty Howie's Avatar
In for the fix.
I would go to the DIC options and change them up a couple of times then set them back where you want them just to see if anything happens.
DH
Old 03-20-2018, 05:39 AM
User Omega
User Omega's Avatar
I would run through the DIC as others have stated and change the alert options.
Old 03-20-2018, 08:12 AM
EVRose
EVRose's Avatar
There is no alert option for unlocking the door!! Why would there be? Think about it. Would you really need an alert to tell you your door is unlocked?
Old 03-20-2018, 09:51 AM
TXGS507
TXGS507's Avatar
dude.. you are the one who posted "asking" for help... ? Members are offering suggestions.. Run through the DIC and disable "Alert" options. Pretty simple. So simple even your wife can do it....
Old 03-20-2018, 11:44 AM
Gboras
6th Gear
Gboras's Avatar
That is the first thing I did. Long before is asked for help on the forum.
To Horn HONKS when I unlock
Old 03-20-2018, 06:22 PM
User Omega
User Omega's Avatar
Gee Sherlock Holmes, how did you get to be so smart.... We were saying to change them anyhow. There could be a problem with the BCM causing this. Maybe if he shuts all of the alerts off it will stop the horn.
Its a suggestion to try as this is clearly not a normal thing to happen. Not the word of Gods.
Old 03-20-2018, 06:48 PM
EVRose
EVRose's Avatar
He tried that already Einstein. Did you read his last post?
Old 03-20-2018, 07:11 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
To me it sounds like a short...might need to get a wiring diagram. If it was me, I'd be experimenting by pulling one fuse (or relay) at a a time here and there to see if makes a difference in sounding the horn. Fuses/relays of circuits that are activated by unlocking the vehicle, whether it be by the fob or door latch (lights, door switch, etc.) Maybe one of those is in close proximity to the horn relay. Could be something jumpering in the fuse block...just my first thought.
Quick Reply: Horn HONKS when I unlock
