[ZR1] Zr1 abs info.
Zr1 abs info.
Is the abs on the zr1 a 4 channel system? I have a 07 z06 and it has the reactive 3 channel abs. Since i have turned this into a track only car, i want to update the abs to a 4 channel system. I know the zr1 has different hubs with different wheel sensors, just trying to make a plan.
Any 09 and up car should have the Bosch ABS. You’ll need 4 new wheel bearings as the spline count is different and the rear halfshafts to match the new hubs. All OEM ZR1 parts will work fine, I don’t have the part numbers handy at the moment.
I’m not sure what all is required to mate the new EBCM to an older car or if the pin outs on the connectors are the same.
