radiator fitment question
Hey guys
I am looking at some radiator options and had a question. Can a regular c6 radiator fit in a z06?
I was looking at the dimensions of the radiator and the z06 radiator is 15 inches tall and the standard radiator is about 18 inches tall. The two parts that connect it are the radiator support on the bottom and on the top.
The top part number is the same. the bottom radiator support is different. 20939829 vs 20939828 do you guys know how much lower the other one is. Mine is broken and ill have to replace it anyway. do you know how much longer the factory on is compared to the z06?
Radiators are not different heights. The difference is the coolers/etc. Depending what year you have, you may have 1 or two coolers in the radiator. You need to check on that.
Im keeping the trans cooler. the radiator I was looking at had the cooler lines on the passenger size. I was on rock auto looking at the measurements and that is where I saw 15 inches. yesterday I measured the radiator and it was 18 inches so I guess I answered my own question.
Thanks for your help.
