C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Motive 3.90 and 4.11 Gears IN-STOCK
Old 04-25-2018, 10:08 PM
  #61
JeremyAZ
JeremyAZ's Avatar
3.90’s came is yesterday. GS is at he shop today to get them installed. Badly needed change for this. Even with heads/Cam & 200 shot it needs 3.90’s.
Old 04-26-2018, 03:00 AM
  #62
dubaitacker
dubaitacker's Avatar
Mine arrived in Dubai on the 22nd just waiting on the J-44616 tool kit to arrive before we try our luck at building one of these units.
Old 04-26-2018, 08:42 AM
  #63
FNBADAZ06
FNBADAZ06's Avatar
You having anything else done to the diff while they have everything apart ?
Old 04-29-2018, 04:08 PM
  #64
NachosZO6
NachosZO6's Avatar
Who's doing your gears Jeremy?
Old 04-29-2018, 05:01 PM
  #65
JeremyAZ
JeremyAZ's Avatar
Hayes transmission in Mesa
Old 04-29-2018, 11:58 PM
  #66
NachosZO6
NachosZO6's Avatar
Nice. Good to see we have a couple local options. We should meet up once the gears are installed to compare notes. 😁
Old 04-30-2018, 12:23 AM
  #67
JeremyAZ
JeremyAZ's Avatar
im always down for play. Heading to LS Fest on the 4th for the weekend.
Old 04-30-2018, 07:54 AM
  #68
double06
double06's Avatar
If somebody gets a set of gears in could they measure the distance across the face of the gears (I think it is like 9 inches). I have seen photos and you can tell the size difference. I always wanted to see what they measured I know the regular C6 ones are like 8.25 inches or so.
Old 04-30-2018, 08:31 AM
  #69
FNBADAZ06
FNBADAZ06's Avatar
It is 9"
Old 04-30-2018, 11:59 AM
  #70
double06
double06's Avatar
Default Thanks
Thank you sir and good luck with results and install. Once you guys get installed please post your views and do gears make noise.
Old 05-01-2018, 01:02 AM
  #71
NachosZO6
NachosZO6's Avatar
Nice. I'll keep an eye out for your vids. Maybe next year I'll be quick enough to make the trip to vegas.
Old 05-01-2018, 01:51 AM
  #72
Megatronss
Megatronss's Avatar
Enticing.......600rwhp and curious what 3.90’s would do for traction. Have NTO5R’s
Old 05-01-2018, 08:30 AM
  #73
jayyyw
jayyyw's Avatar
Make it worse.
Old 05-01-2018, 11:59 AM
  #74
FNBADAZ06
FNBADAZ06's Avatar
Originally Posted by jayyyw
Make it worse.
Understatement
Old 05-02-2018, 07:19 AM
  #75
Mike44665
Support Corvetteforum!
Mike44665's Avatar
My $0.02.
Back in my days of muscle cars, my 1969 Z/28, 2.20 first gear, 3.73 rear end. When you tried to launch on street tires, the wheels just fried the tires because the were spinning so fast. After the install of 4.88's, drop the clutch at 3,500 RPM and nail it, no frying the tires and the car left, gone, see the USA from behind my Chevrolet, ate Road Runners and 440's alive.
I read an article where they had a 302 in a 69 Camaro race car. Testing to get the best times they had really low gears, 5.38's if I remember correctly. Then they swapped the 302 for a big block, both were race motors. The car slowed down. They ended up going to a taller gear because of the rotating mass of the BBC would launch the car better with a tall gear.
I think the lower gear will help E.T. times on the Vette race cars, but then I'm old and may be full of baloney.
Old 05-02-2018, 07:57 AM
  #76
double06
double06's Avatar
I understand the theory behind that is that the car/tires will reach a speed when they wont spin - less tire speed shock to the system. I think also with the low gear in your example above there may have been more weight transfer to the back with the 4.88, thus helping traction. It will spin easier with the lower gear like the 3.90s as there is more torque to the tire.
Old 05-02-2018, 08:08 AM
  #77
Apocolipse
Apocolipse's Avatar
Received 1,283 Likes on 928 Posts
There is MORE torque at the wheel with a 4.88 vs 3.90...
To Motive 3.90 and 4.11 Gears IN-STOCK
Old 05-02-2018, 08:44 AM
  #78
FNBADAZ06
FNBADAZ06's Avatar
Here's my post on torque multiplication from transmission to rear gear to wheels.
https://www.corvetteforum.com/forums...omparison.html
My current acceleration plots with 3.42 read gear.....
All the parts to put the 3.90 rear gear in my diff have arrived, so I’m dropping the diff off this weekend, then the car goes back together. Then, I’ll be able to compare the numbers with the 3.42’s to see the impact on overall acceleration. For 1/2 mile races I’ll be shifting into 5th gear now, but I’ve got the .81 5th gear in my ZR1 transmission so this will be very interesting. Here’s some data from my last 1/2 mile run that I’ll be using as my baseline:
Standing start 1/2 mile 166.1 mph@ 18.50 seconds.
I hit 170 mph in 20 seconds, and hit 172 mph in 3005’ ....all in 4th gear at 7400 RPM.
This was on my 335/25/20 street tires in street trim
Standing start to top of 4th gear...172 mph in 3005’ ....all in 4th gear at 7400 RPM.
Since switching to the MH3 ZR1 transmission (2.29 1st gear) my 0-60 Mph and 60’ launches have suffered big time, but I knew that as I had always had 3.90’s in mind. Check out my 1st gear acceleration plot with my 3.42’s and 335/25/20 street tires..... 73.47 MPH in 1st gear !!!!
Acceleration plot showing speed/distance/time for 1st gear pull shown above
Old 05-02-2018, 10:58 AM
  #79
AzDave47
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
Victor, you are a treasure of good technical information!
I timed from my GoPro at Mojave and was about 15.7 sec. to 150 with serious 1st gear tire spin and 1-2 shift spin on the runway. It was 38 second to the 1.5 mile trap, taching ~6400 RPM, stock size tires, rear gear and tranny gears.
Old 05-02-2018, 11:08 AM
  #80
MMDAZ
7th Gear
MMDAZ's Avatar
3,90's in the ZO6 made it much more of an amazing car to drive, did i lose some top end sure but it was worth it.
Quick Reply: [Z06] Motive 3.90 and 4.11 Gears IN-STOCK
