C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] WGF Dallas...
Old 04-18-2018, 09:13 AM
  #41
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
Keep us posted Anthony... Good stuff...
Originally Posted by Mordeth
Still much better than the weather here. They closed Watkins Glen today and kicked everyone off the track. 30 degrees and freezing rain, sleet and snow. Track was literally iced over. I've never seen it shut down in mid-April.
I am racing with AER (American Endurance Racing) this Saturday and Sunday for a Porsche Racing team. Thursday is practice. Friday is qualifying and then the 18 hour race is Saturday and Sunday.
I will be racing against Randy Pobst. Pobst is in the yellow BMW #395. I will be in the white Porsche # 336 (Anthony). 95 race cars so far.
Watkins Glen International April 20 - 22, 2018
AER
Old 04-18-2018, 10:36 AM
  #42
FSTFRC
FSTFRC's Avatar
newchevyman,
Did you have a engine issue? Still stock cubic inch motor?
168 is getting it done sir!
thanks..
Old 04-18-2018, 11:38 AM
  #43
jayyyw
jayyyw's Avatar
Originally Posted by newchevyman
Sorry guys lots of overtime last two days. Setup is:
Diamond forged pistons
Improved Racing crank scraper
Advanced Induction 280cc heads
243/258 on 114 LSA (RPM B3)
2" ARH/3" ORX/3" Borla Touring
Mamo MSD/NW 102/Vararam
Mezeire EWP/ATI 10%/catch can/160* t-stat
RPS street lite twin disc/stock T56/MGW
trans/diff/clutch fluid all replaced a few weeks before event
I picked all the parts. Andy Canaan did the mechanical work. James Karger tuned it.
Rear tires used were Weld 18x11 with 345/35/18 MT ET Street SS. Fronts were 18x7 Welds 245 width. No weight reduction. Not sure how high 4th would run out to but the shift up arrow on the HUD had been on 2-3 seconds and I stayed in it. I was frustrated with car as it was supposed to be tuned on E85 last week but scheduling issues prevented that then I also bought base C5/6 rear brakes to try and shed some rotational weight but they didn't work out either so I decided screw it run it as is. With minor weight reduction and E85 no telling what it would've run. I'll add pics in a little later
Edit: Matt, I sold you the AHP heads and years ago the fourth gen ZR1s
Sounds like a stout setup. What was wrong with the base brake conversion? I kind of went through a mess getting mine. They sent me brackets for the Z51 brakes and I had to get the correct brackets from GM. I also broke the rear rotors doing a couple 160+mph runs on nitrous, back to back. LOL
Old 04-18-2018, 11:44 AM
  #44
newchevyman
newchevyman's Avatar
Originally Posted by FSTFRC
newchevyman,
thanks..
Think it had a blown head gasket. Took it to Andy at that point and he said there was a ton of coolant in the oil. Had machine shop test the block it wound up being fine so I went ahead with forged pistons and the crank scraper. It's "technically" a 428" they're 4.130 pistons so I consider it stock cubes. I've never had any issues with it in 4k miles since. Car hauls *** and has great street manners given the cam size which is all I cared about. Made 611/519 on 93.
FSTFRC (04-18-2018)
Old 04-18-2018, 11:54 AM
  #45
FSTFRC
FSTFRC's Avatar
Excellent! Thanks for sharing!
I was curious why you changed the pistons, 168 mph is getting it done.
I ran a best of 164.23 mph
Old 04-22-2018, 01:51 PM
  #46
BAAD LS2
BAAD LS2's Avatar
2018 Corvette of the Year Finalist
2017 C6 of Year
Originally Posted by 0H8Z06
Pretty sure you were in the Blue ZR1.... Unless I am mistaken your first run was 149 or so then I saw you sitting at the end of track perhaps tweaking your tune... Gorgeous car!! Wish we could have lined up for that first pass...
Haha yeah that was me. Car went into limp mode, had to reset the battery for some reason. Think my tb slammed shut. Got it restarted and hot lapped it to 170.
Old 04-22-2018, 02:22 PM
  #47
Millenium Z06
Moderator
Millenium Z06's Avatar
Originally Posted by LMB-Z
Just curious...what does a stock Z run in this event and how much hp does it take to run 160 mph? I've never been to one of these events. Never been 160 mph either...lol.
Stock is around 145-148mph. 580-600whp will put you around 160-162mph. Most ppl running at that event were 4 mph faster than last November without the tail wind
LMB-Z (04-22-2018)
Old 04-22-2018, 02:25 PM
  #48
Millenium Z06
Moderator
mine did that last november and it turned out to be the TPS
Old 04-22-2018, 06:54 PM
  #49
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
mine did the same on Sunday AT the event... I got one decent run in (my first) and the rest sucked because of this... weird it never happened to me before and I have no idea how the pins got spread apart but oh well, I'll be back in November hopefully
Old 04-22-2018, 07:00 PM
  #50
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Common issue, adjust the tune so it doesnt go into limp mode for TB issues.
Old 04-22-2018, 08:32 PM
  #51
Millenium Z06
Moderator
Yeah, that's what we had to do when retuning for the new TB until we got the scaling correct
Old 04-22-2018, 08:33 PM
  #52
Unreal
Unreal's Avatar
Not even a scaling issue, just big power builds, and TBs start to wear out, so you get some flutter, or doesn't return quick enough, so you get a REP mode, and kills a run. Have to reflash, and start over. Just adjust the TB error settings.
Old 04-22-2018, 08:36 PM
  #53
Millenium Z06
Moderator
I got two good runs last November and then the throttle body went ape ****.
Set off all kinds of codes at 155+, active handling, traction control, charge system. The car actually shut down at the top of one run, dead, dash lit up then as soon as I got off the throttle, it restarted.
Old 04-22-2018, 08:42 PM
  #54
Millenium Z06
Moderator
I went from the LS2 (ported) to a TPIS LS6 style so I could replace the TPS if it failed again without replacing the whole TB. The new one flows a lot more air than the ported LS2 so the scaler was way off.
I think the LS2 TB did get some flutter and it had a return issue and the car went to REP mode until a reset. Luckily it didn't completely die until I got the car home.
Old 04-22-2018, 08:43 PM
  #55
neutron82
neutron82's Avatar
pretty much the same thing happened, it would trip tps/traction codes and go into rep and I coasted the rest of the way while trying to clear the codes to get the car running and slow down at the same time... it happened once on the 3-4 shift and the second time was nearly at the end of 4th... aside from wot runs the car ran perfectly fine
Old 04-22-2018, 09:54 PM
  #56
Millenium Z06
Moderator
Yep, mine would go crazy at the top of 4th. The next weekend when I got a chance to look at it and take it for a test drive, it would start and drive just fine but as soon as you hit wide open throttle it would go into reduced engine power mode and set off TCS, active handling and charge system fault
Old 04-23-2018, 09:22 AM
  #57
TXGS507
TXGS507's Avatar
Gorgeous, fast C6ZR1...
Quick Reply: [Z06] WGF Dallas...
