[Z06] Question for Owners running a Vararam with a Front License Plate
Technical guys at Vararam recommend NOT running a center mount license plate (like the Top Flight) as airflow restriction on C6's reduces Vararam performance (and presumably impacts radiator cooling).
Looks like there are several options for brackets that will mount on the side of the grill opening and not interfere with airflow to the engine compartment as the sides are blocked behind the grill anyway.
Would like to hear what bracket you use. Am hoping to find one that mounts securely and doesn't require drilling.
Suggestions to remove the Vararam or simply continue to pay fines are not going to be helpful.
Pictures of how your side mounted bracket and plate look would be Very Helpful!
Thanks in advance for your help!
