Eliminate the 1-4 Skip Shift Feature with this New product from RPI Designs!!!
Platinum Supporting Vendor
="5"%C6 Corvette Skip Shift Eliminator CAGS Fuse
="4"%Website Link: https://www.rpidesigns.com/shop/item...tor-cags-fuse/
="4"%If you are looking for a quick and easy way to eliminate the 1-4 skip shift feature on your C6 Corvette this C6 Corvette Skip Shift Eliminator CAGS Fuse is just what you need. This special skip shift eliminator fuse is designed to replace your factory fuse and disable the 1-4 skip shift feature. Installation could not be any easier, just remove the factory fuse and replace it with our custom fuse. Our fuse will light up letting you know that it is working and that you can now enjoy driving your Corvette without being bothered with the skip shift feature.
Fitment: 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013 C6 Corvette Base Coupe, Convertible, Z51, Grand Sport, Z06, ZR1 w/stick shift
="3"%Use Coupon Code RPICHRIS5 at Checkout and Save!!!
__________________
Use Coupon Code RPICHRIS5 for immediate savings!!!
Thank you for the orders!
Well There is this............
