Drain plug in dry sump tank?
Took the dry sump tank out of the car. There was definitely a fair amount of gray sludge at the bottom of the tank. By the looks of the tank it seems like this would be a good time to add a drain plug at the bottom of the tank. Has anyone ever done that? I’m surprised the factory didn’t add one here. Seems like it would be a good idea to have a drain plug in this location. If you look very close the hole at the bottom is threaded. Anyone know why?
Well I went ahead and had the bottom of the tank drilled out and welded in a drain plug. I will now be able to drain 6-7 ounces out of the bottom of the tank after all the oil is drained from the oil pan.
