Let's talk rear spoilers
will probably get flamed here but does anyone make a ZR1 type spoiler that utilizes the stock Z06 Spoiler mount locations but allows you to use 3M tape to secure the outer parts of the spoiler? I just want to make sure I like the look before I drill perminate holes in my rear fascia. I dont do high speed runs or any track days. It would mainly be for looks since I am adding the front splitter and side skirts. I did search but not a whole lot of useful info. Thanks in advance.advance
Received 1,679 Likes
C7Carbon has em..I currently have mine attached w stock bolt location and 3M tape. I'll be replacing it this weekend. Here's mine.. Installed in probably an hour taking my time.
What you're asking has been done many times. Just need a real high quality automotive double-sided adhesive tape.
how long have you had it installed with the tape and how has it held up? My main question is do you have to cut the outside studs off or do they unscrew? I add m wanting to do carbon fiber to match my splitter and skirts.
The C7 only uses stud were the stock holes are. The two other attachment points you screw in bolts to the spoiler. So if you don't wanna drill them you can just use double sided tape instead.
Excellent! Thanks for the info. I will look to C7 Carbon when the time comes. Hopefully the carbon weave will somewhat match my RPI splitter and skirts.
I too would recommend you bolt it down. I have ran two WGF events with mine. Installed about a year ago. There are hairline gaps.. As I can see water flow underneath it when I wash it.
( in some areas). It is a very nice piece.
Just installed my Wickerbill C6.5
Flush.....
