C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Full effort mods vs. supercharger
Old 06-29-2018, 06:15 PM
ssbowtie1
ssbowtie1's Avatar
Default Full effort mods vs. supercharger
I've been pretty curious about this lately. When you factor in a cam/heads/headers/intake/cai/install/tuning for a max effort LS7 to get to ~600whp, you can spend about the same amount to get a supercharger kit and make about the same power, with less hassles of cam drivability, header issues, intake leaks, etc.
Is it because people slowly mod their cars, so they don't feel the $6-$7k sticker shock?
Old 06-29-2018, 06:19 PM
slow_zo6
slow_zo6's Avatar
Pretty sure the ls7 isn’t the best candidate for boost because of the cylinder walls.
Old 06-29-2018, 06:22 PM
nuke61
nuke61's Avatar
I did heads/cam because I just like the sound and feel of a heads/cam car, it had nothing to do with money, because I dropped off a B&B only cat-back car and picked up a heads/cam/intake/headers car, with a bill of ~$8k. I had a supercharged C5Z and I just didn't want to go that route again. Even though my C6Z might be slower than my C5Z, I find it more fun to drive.
ssbowtie1
ssbowtie1's Avatar
I've heard that as well but there are quite a few boosted LS7s on 4-6lbs running for thousands of miles with no issues. ECS, A&A, TPS, and multiple forum members attest to it.
Old 06-29-2018, 06:24 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
If NA doesn't matter to you, sell the car, save the money on the mods and apply it towards a C6 ZR1 if you wanted an FI car. JMO...
The following 3 users liked this post by MTPZ06:
furiousox (07-03-2018), NotreOkc (07-02-2018), TRSCobra (06-30-2018)
Old 06-29-2018, 06:29 PM
ssbowtie1
ssbowtie1's Avatar
But why not the best of both worlds with the LS7
I'm just trying to see if I'm missing something because there are way more HCI LS7 than SC LS7s but you can make the same, if not more power without any of the drivability trade offs or dealing with nuances of multiple mods.
Old 06-29-2018, 06:34 PM
redbird555
redbird555's Avatar
it’s already been said....the ls7 doesn’t like boost even at 4 psi making 600whp is generally less safe than making that same power with a cam
Old 06-29-2018, 06:48 PM
redcycle13
redcycle13's Avatar
The feel of a lightweight Z06 is better accentuated with an extremely responsive heads and cam combo IMHO. A supercharged car just feels different, and you would need to experience both to truly understand the differences. With the large displacement of the LS7 you can get similar power to a boosted combo, and retain the lightweight feel.
Old 06-29-2018, 08:35 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Heads need to be done either way. And 600rwhp of cylinder pressure is same. Walls don't care. Problem is 4-5psi can easily be 700+ .Hard to only make 600
Old 06-29-2018, 09:54 PM
Indepth
Indepth's Avatar
You've got a PM incoming.
Old 06-29-2018, 10:18 PM
73DBG
73DBG's Avatar
Can’t go wrong with Unreals advice. And you can have a heads/cam set up with a SC, I’m making around 700rwhp with 4.5 psi right now, AHP heads are ordered and I’m very impatiently waiting on those lol, not sure what the car will make after the heads go on. I also added billy boat bullets so I have 3in all the way now, got the Dallas performance big mouth intake as well but it needs some tweaking to fit over my radiator/intercooler set up. Fuc it bro....full retard and do both H/C/I and SC......🤔🇺🇸💸
Old 06-29-2018, 10:27 PM
ssbowtie1
ssbowtie1's Avatar
On a stock bottom end?
Old 06-30-2018, 12:00 AM
73DBG
73DBG's Avatar
Yeah, dudes push way more than 700 on stock bottom ends all the time. Will I upgrade in the future....maybe, but I have no real concerns about 700-800rwhp at 6/7 psi on a stock bottom end. It’s not a daily driver or a dedicated race car, **** there’s a ton of dude on this forum running way more boost and making way more power on stock bottom end.
Old 06-30-2018, 12:03 AM
73DBG
73DBG's Avatar
He can correct me if I’m wrong but I think unreal has had several 1000hp boosted cars on a stock bottom end. From what I’ve seen the pistons and adding sleeves would be the most beneficial to F/I than forging the bottom end.
Old 06-30-2018, 12:06 AM
Unreal
Unreal's Avatar
No where near stock bottom ends. All big dollar builds. 1000+ and budget don't belong in same sentence.
Old 06-30-2018, 01:04 AM
Innovate
Innovate's Avatar
I would not boost an SBE LS7 unless you run around 700-750 rwhp at most. Most people know this and purchase a C6Z for NA power. That is unless you plan on Darton Sleeves or a whole new ERL/Dart block or something to go boost. Heads would need to be addressed regardless of boost or staying NA.
Old 06-30-2018, 10:21 AM
meanjoe
meanjoe's Avatar
LS7 was never meant to be boosted.
To Full effort mods vs. supercharger
Old 06-30-2018, 10:49 AM
CASEWORER
CASEWORER's Avatar
Although it was never meant to be boosted this engine responds very well to small and mild levels of boost. 700-750 very easily attainable with only 6 to 7 lbs of boost. However having said that the LS 7 blocks cast iron sleeves are very thin and brittle and IMHHO the above power levels are pushing the limits of the cast Iron sleeves. The stock bottom end is fine up these levels. HP is a addictive drug and once boosted it is very easy to increase levels of boost this engine was just not designed to handle hence the LS 9. If you honestly believe you will stay happy with only small amounts of boost go for it. But BEWARE the urge for more power will rise its ugly head and then you will have a serious problem.
Old 06-30-2018, 11:47 AM
Pb82 Ronin
Pb82 Ronin's Avatar
OP in the typical fashion, I can answer your question with the always correct answer of, "It depends." There are so many factors that contribute to the desired outcome and your overall happiness with your car. For every HCI build, there is likely folks that chose the other way (FI) because it made more sense to them for what ever their criteria for success were. It is not incorrect to say in that most power mods (usually) requires supporting mods. And that's where the sticker shock can skyrocket. The answer is, either way can yield the results you're after. But you have to determine what you're building the car for. Do you want a certain HP, stock like driveability, cheapest on the wallet, best looking/sounding, etc...? It's all relevant. Figure out those questions, then proceed on the path to get you there.
Old 07-01-2018, 12:33 AM
MTPZ06
MTPZ06's Avatar
Its not the best of both worlds...the LS9 is a forged bottom end, the LS7 not so much.
Quick Reply: Full effort mods vs. supercharger
