[Z06] Bauer Motorsports Build: WCCH All Pro 290, Solid Roller, ERL 454, 14:1 SCR
#181
Some pictures of the Isky Solid Roller Lifters. These are double offset to help the 7/16” pushrods clear. I went with the optional EZ Roll bronze bushings in the wheels. These also feature forced pin oiling.
The following 3 users liked this post by Josh B.:
jayyyw (08-20-2018)
#184
I've used 3 different valve spring compressors for working on LS7 heads. None of them were designed for LS7 heads, so all had to be modified and were really less than ideal. None of them are photogenic if you know what I'm saying.
But I just picked up this LSM Products Valve Spring Compressor that fits my T&D rocker stands perfectly. Very happy with this new tool. I removed two of my springs almost one-handed.
HC Mechanic (08-25-2018)
#185
St. Jude Donor '13
[QUOTE=Josh B.;1597833136]I've used 3 different valve spring compressors for working on LS7 heads. None of them were designed for LS7 heads, so all had to be modified and were really less than ideal. None of them are photogenic if you know what I'm saying.
/QUOTE]
That is a really nice valve spring compressor! Do you think that tall of a piece would work doing a wiggle test?
/QUOTE]
DualQuadDave (08-02-2023)
#186
It is another Josh work of art!
#187
High dollar heads deserve a high dollar spring compressor! I have a wine opener that kinda looks like that...
#188
LSM makes great tools, I used the SC 167 when I did my springs, well worth twice the money as the junk spring compressors
#190
[QUOTE=MickVette;1597833467]
It's designed to be used with the heads still mounted to the engine so I don't think it would be a problem at all. It's a really nice piece.
/QUOTE]
/QUOTE]
#191
#192
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Looking great Josh. It's getting closer! Man you gotta be getting anxious (in a good way).
And agreed on the LSM tool. Really wish I had bought it sooner than I did. I let my buddy borrow my junk comp version and he never returned it. Prompted me to buy another one so I went with LSM. Just did my routine spring swap about a week ago and it was a walk in the park. I thanked my buddy for stealing that POS after using this one.
#194
The following 2 users liked this post by Josh B.:
HC Mechanic (08-25-2018),
HP RESEARCH (08-23-2018)
#195
You will have to see but I think you will find the Weisco piston generous valve relief should give you the clearance you need - subject to the increased diameter of the valve. I think if I remember right they are like another .100+ more than stock.
#196
Checking the rocker stand height today. The process required the removal of one of the rocker bodies from the shaft, then using a provided gauge to determine if the correct height was there.
Mine was flush on the valve tip and the rocker so we are good. Got to tip my hat to both WCCH and T&D for precision maching here. Two different machining operations. Still a perfect fit.
#198
Thanks. I really admire the engineering that went into some of these parts. It will be a few weeks. We have a newborn now and my dissertation is keeping me busy, but I'm putting time into the project whenever I can.
#199
Checked valve cover clearance yet?
