[Z06] Clutch or Master? Help!!
Whats up Guy,so to make it quick...I was out racing other night. Did a quick burnout to warm tires up. As I pulled up to a light I Noticed clutch pedal felt weird.
When I depressed the clutch and tried to put car in gear I couldn’t . I tried to put it in a few different gears, you can feel car wants to move. I still had a clutch pedal.
So yesterday I pulled the drivetrain (car on jack stands on my back) lol . Look at the clutch (twin mantic) nothing looked unusuaI. I put a new slave cylinder , new speed bleeder. Had the car Buttoned back up in 9hrs. Bled the clutch. Feels like a good pedal and had solid fluid when I was bleeding .
Started the car last nt , depressed clutch and same thing car won’t go into gear . With the clutch engaged and trying to put it in gear you can feel car wants to move .
Yes I was very upset lol. All that labor.
You think ink maybe it’s the master cylinder? Or the clutch?
Thanks Jason
Thanks Jason
IF MC is original it may very well have given up the ghost.
A member posted pics showing how seals deteriorate allowing fluid to pass.
No fluid pressure no clutch, w/ a visual inspection of clutch & a new SC what else could it be?
Replacement MC are neither expensive or difficult to install, especially for anyone skilled, like you.
FWIW conventional wisdom has long blamed the cheap seals GM used behind the reason fluid gets so dirty so fast.
There was a semi-recall re bad MCs, IF customer complained of soft/erratic clutch a new MC w/ improved seals would be replaced on GM's dime.
Had it done on my '08 couple years ago.
Of course this 'silent' warranty's only good for cars 10 yrs old or newer.
Mileage limit also but mileage probably isn't your issue where in-service date may be, how old's your C6?
G/L, update thread...betting MC.
BTTT
BTTT
BTTT
BTTT
Im going to take a little break from the car this week bc I’m so frustrated. Oh..the car is a 2008 H/C nitrous stock bottom end. 615rw on motor 780rw on 150 shot.
It sounds like your clutch is dragging which would make it hard to engage a gear and cause it to want to walk when in gear.
Ie when you push the clutch in it doesn’t fully release from the flywheel. Or the pilot bearing is grabbing the input shaft.
Broken clutch or messed up pilot bearing would be my guess since it worked before and you replaced the slave.
Can relate to wanting to cry after all that work.
Tell you this though when I've been stumped by anything, taking a break was always beneficial in finding the answer.
More pissed I get more brain misses clue(s) every time.
Take a break, look at it again w/ a clear head & update. G/L
Thanks for feedback guys Update..After talking to a few people, I’m leaning more towards Clutch failure. Maybe Pressure plate maybe shattered or crack. I really don’t think it’s Hydraulic. Going to get the up in the air again tomorrow. Before I start pulling drivetrain again,going to use a camera and see if I can possibly see the slave pushing on forks when I press the clutch. At least rule out master.
I been kicking myself all week bc I was rt at the clutch and should’ve took the extra 20mins, and pulled headers, bellhousing and clutch. And Really inspect it. The clutch was last on what I thought was wrong. Rushing also has reverse progress sometimes.
Let you know what I find out. Thanks Jason
Landru (07-18-2018)
Problem started after a burnout. You sure you didn't smoke the clutch and not the tires? Crazier things have happened. If you can't get the car in any gear with the pedal depressed (and you have a good pedal) it's the clutch. Pressure or floater plate related, since clutch isn't disengaging. Did you remove the clutch when you inspected? Or just look at it?
I had mine replaced right at the deadline. Mileage was ok but I timed out at just shy pf 10 years. They replaced my master with one from a zr1. Its black and dont show how dirty the fluid is. There was a bulletin on it but never a recall. And the symptoms had to be duplicated. No problem with mine as the pedal was to the floor. Sorry....refering to the master cylinder
Clif
Clif
What’s up guys been crazy busy with work and also with a baby on the way in 2 weeks the wife has me doing a million things anyway... I finally got around to pulling the drivetrain back out,and this time took the bellhousing off lol.
Pulled the clutch apart, and found my problem..
Clutch discs are Done!! One spring completely pulled out and was floating inbetween plate and flywheel. Did minimum damage besides scoring some flywheel bolt heads. Also you can see in pictures, stress cracks on both discs around springs. Looks like they all were gna let go too.
Although it’s only two years old,I can’t knock this Mantic clutch. It’s has been through a lot of abuse. 100s of 1/2 mile passes , multiple low 9sec passes on nitrous,and a lot of miles on street. I thought I would get more out of her, but hey that’s race car problems.
I won’t be putting a Mantic back in the car. I already bought a Monster Lt1-s Triple. And Honestly I can’t wait to install it this weekend. Heard and read nothing but great things about the clutch. And I love the fact it’s heavier than the Mantic.
I have a big cam in my car and I always felt the lighter flywheel was a issue as far as drivability.
What I seen first time around.Looks normal.
Landru (08-03-2018)
Glad we all could help. How much power do you make on kill mode?
OP, Congratulations on the baby on the way. And congratulations on finding your issue. Dont beat yourself up over this. As we all had these issues once in our lifetime. I'm glad you got it fixed.
Are you doing the triple disc monster or ceramic monster? Thanks. Great learning post for is all.
Thanks brother. I always appreciate all the help and advice on the Forum. So the old set up I ran for two years was.. H/c sbe made 567rw on motor 646rw 150shot ( mustang dyno). Car went 10.09@139 Na / 9.43@149 on spray. With this Mantic. Cut 1.40 ft’s constantly. New set up this season from doing some winter mods . Msd,milled heads,Nw,2”
headers ..I make 615rw Na and 780ish 150shot (spinning on dyno) same mustang dyno. I haven’t been back to track with the new set up. I broke the clutch roll racing on street.
Hopefullu this fall I get back to track and go for sub 9’s
The Monster was 57lbs. My old beat up Twin Mantic was 18lbs. Huge weight diff!!!
I purchased this Mantic when Ecs first starting selling them, and I believe they only offered a light weight flywheel. I always wanted a heavier flywheel. Really can’t wait to see have this Triple works with my set up.
It works, plain and simple. It will hold all an LS can throw at it.
Haha you know what..every time I have to work under the car I say I’m never doing this again lol. Being I don’t have a lift and I put the car on jack stands, that adds to the time. Although I have a system now and I can have the car in the air in about 20mins. I get it about 18inches from bottom of sideskirt to the ground. Once car is off the ground I can have the drivetrain out from under the car in 3-1/2 hrs. That’s removing center console,exhaust also. I did it so many times it’s actually easy to me.
