[Z06] Front Turn Signal Bulb Replacement
Hi All,
Anyone ever changed one of the front headlight turn signal bulbs before? Noticed one of mine is out so that side blinks faster than it normally does. Any help would be appreciated!
There's a rubber flap behind the wheel that's held with push clips. Remove that and you'll have access to the turn headlights and turn signals. If you have big arms & hands it'll be tons easier to jack up the car real quick just to change it. I fought with myself trying to change it without the jack and can't get my arm in there so it literally took me 1min to get the jack out and lift it up with 3 pumps and made it tons easier.
There's an excellent youtube video on this topic if you do a simple google search.
Good luck, don't cut yourself
BTW, I recommend you replace both sides at the same time. Bulbs are usually sold in pairs and you want them to match. I had a C6 behind me the other day with two different colors/brightnesses of DRLs. It was pretty funny. The only way to guarantee a match in brightness and color is to replace both sides at the same time. Besides, if one went out, the other side is probably not that far behind.
