What the **** !!!!!
What the **** !!!!!
Having just gotten round to changing the stock clutch, which has been very good at handling the extra Lingenfelter HP, apart form the high RPM no pedal return, due to the release bearing support failure (yes that piece of plastic in a very harsh environment !!!) There is, as many of you know, lots of things to disconnect, move and remove before you can even get to it.
Well, having drained the oil, I disconnected the flow and return oil pipes at the sump. As i did, there were two distinct clunks in the pan that the oil was draining into. Having poked around in the oil I found two pieces of what seem to be rough aluminum casting, as they are not magnetic and shine up on a grinding wheel. The smaller piece got destroyed trying to establish what it was made of. the bigger piece, shown, is as it fell into the pan. WHAT THE **** The car has never shown any abnormal oil pressure readings but guess it depends where the reading is taken.
I can only think the two pieces broke off during the casting / cleaning process
Any thoughts or comments appreciated
